1968Commando
Homemade clevis hitch
1968Commando
I’m making a homemade clevis hitch, what’s the diameter for the pipe piece? Also what is the bolts that go in there what size are those??
oliver2-44
Go to the "Implements and Attachments Section,2nd post down has a detailed drawing of a hitch.
gwest_ca
Handy Don
There can be a ridiculous amount of rotational torque on a sleeve hitch so be sure the cross-to-legs and sleeve-to-cross welds are some of your best work. That most of these are bent from straight bar stock is not an accident.
AlexR
Posted (edited)
I thought I had posted about one I made but apparently not.
The bolts are 1/2" bolts I forget how long probably 2 1/2"
I do remember I used some steel pipe (like black pipe for gas and cut the threaded ends off) for the pipe piece you are talking about I believe it was 1/2" pipe you will have to measure ID to verify it's 5/8" you might still have to run a drill bit through to clean it out.
Like has been mentioned I would recommend bending it, but looks like you are past that point.
Edited by AlexR
