ML3
Posted (edited)
Going tomorrow to look at a 416H- about an hour away. Seller told me he purchased house & tractor was out in shed. He claims he had it serviced/inspected, oil change,  new battery, new tires. Paint is a bit faded & he wasnt sure of engine hours. Supposed to run great & he has mowed with it but has another tractor (green🤫) that he prefers. Included w/tractor is mower deck, rear wheel weights, & front plow. He did admit that the hydro is "jerky" when going from forward to reverse or reverse to forward. Anything that I should really be looking for other than the typical things I already know to inspect?
Edited by ML3
  • Thanks 1
Lee1977
Could be wear in the cam and cam plate. My 520 had a notch wore in the cam when I got it. I would have to hit the brake to get it out of reverse. I replaced both
  • Excellent 2
cjb398
Reversing direction on my 416-H can be jerky if I am careless with my shifting. I have the steering column mounted shifter, and with the need to push down going into reverse and letting the shifter rise up when moving to forward, there can be a sudden reverse of direction that can be characterized as a jerk. Just the nature of the shifting linkage. If you pay attention and shift deliberately and smoothly, there is no jerk.
Chuck
