Wheelhorse#1 1,996 #1 Posted July 1 Hello all ! I acquired a 1968 Commando for free of charge.He would not take any money but I did gladly purchase a brand new seat he bought for it. The nice gentleman that owned it had plans to restore it unfortunately life got in the way decided to give it up.It then sat for about 20 yrs. Until I came along lol Its partially disassembled but all the parts are there.He even bought a decal set and some odds and ends parts. I have it running and it runs great all it needed was a carb rebuild kit and a condenser and a couple gaskets- so far. Engine was Rebuilt at some point and still has hone swirls in the cylinder,no smoke the deck is usable as well just needs some love. Im redoing the wiring now and in need of an ignition switch . He was a member here at some point not sure if he still is. He just wanted someone to bring it back to life and not go to scrap and he knew I would do that . Someone at some point in its life decided it needed a racing stripe not sure how I’ll Handel that but I think it has to go . Enough rambling a couple pix for now . I told myself no more WHs well we know how that goes ! 13 Share this post Link to post Share on other sites
Achto 32,686 #2 Posted July 1 (edited) 1 hour ago, Wheelhorse#1 said: Someone at some point in its life decided it needed a racing stripe not sure how I’ll Handel that but I think it has to go . If your not going to repaint the tractor, then I think it's best to leave it. Character marks, battle scares, poor decisions at a young age - what ever you want to call it. Edited July 1 by Achto 7 2 Share this post Link to post Share on other sites
WHX?? 58,114 #3 Posted July 1 Some models (Bronco's ??) did have a stripe there. 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #4 Posted July 1 (edited) 44 minutes ago, Achto said: If your not going to repaint the tractor, then I think it's best to leave it. Character marks, battle scares, poor decisions at a young age - what ever you want to call it. I believe you are right .Best to leave it . have no plans to paint it at all Edited July 1 by Wheelhorse#1 3 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #5 Posted July 1 Anyone know what this is for? I looked at the parts break down for the Commando and didn’t see this listed . looks homemade or repaired, some kind of bracket ? 1 Share this post Link to post Share on other sites
Treepep 1,151 #6 Posted July 1 @wheelhorse1 Sorta looks like an attach o matic front mounted something??? That year even Have that option? I know very little Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #7 Posted July 1 (edited) 3 hours ago, Treepep said: @wheelhorse1 Sorta looks like an attach o matic front mounted something??? That year even Have that option? I know very little I figured it out .Its a bracket for the seat ,goes under the rear fender pan. Not sure if it’s original,I don’t think so but I’ll look into it further. Edited July 1 by Wheelhorse#1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #8 Posted July 1 (edited) Its a home made bracket for the seat pan so it can tilt back to have access to the tool box it works but sits high. maybe someone was a midget and needed to sit higher on the seat ? or to fit over sized tires on it . The rear fender pan is missing the ears. Someone sure did put a lot of time in welding it up that’s for sure . never know what you may find on these old tractors. Edited July 1 by Wheelhorse#1 7 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #9 Posted July 1 Looks like a good project. Do NOT use that seat bracket unless it can lock down. Ask me how I know...... 1 2 Share this post Link to post Share on other sites
Blaine 276 #10 Posted July 1 Maybe it was used to raise the seat pan to run some giant tires on the back, to go with the “racing” stripe. 1 1 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #11 Posted July 1 4 minutes ago, Blaine said: Maybe it was used to raise the seat pan to run some giant tires on the back, to go with the “racing” stripe. Yes Sir It’s all coming together now .Makes perfect sense . 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #12 Posted July 1 (edited) 11 minutes ago, ebinmaine said: Looks like a good project. Do NOT use that seat bracket unless it can lock down. Ask me how I know...... 😆 Someone actually thought of that and made a cut out for the latch . Hope your weren’t popping wheelies when that happened. Edited July 1 by Wheelhorse#1 2 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #13 Posted July 1 20 minutes ago, Wheelhorse#1 said: 😆 Someone actually thought of that and made a cut out for the latch . Hope your weren’t popping wheelies when that happened. Oh no no. The Cinnamon Horse tried to leave without me!! 1 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,133 #14 Posted July 1 4 minutes ago, ebinmaine said: Oh no no. The Cinnamon Horse tried to leave without me!! So, your Horse tried to buck you off??? 2 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #15 Posted July 1 16 minutes ago, MainelyWheelhorse said: So, your Horse tried to buck you off??? Tried?? No. It succeeded quite well. There's an old post.... 4 Share this post Link to post Share on other sites
953 nut 69,283 #16 Posted July 1 11 hours ago, Wheelhorse#1 said: Im redoing the wiring now and in need of an ignition switch . The early ignition switches ( # 7262 )can be hard to find and rather expensive if you do find them. The wiring diagram below uses a reasonably priced 103990 ignition switch and a solenoid. 1 1 Share this post Link to post Share on other sites
AlexR 3,109 #17 Posted July 1 10 hours ago, WHX?? said: Some models (Bronco's ??) did have a stripe there. Broncos, Chargers and Raiders I believe it was a option from 70-72 1 Share this post Link to post Share on other sites
953 nut 69,283 #18 Posted July 1 (edited) 14 minutes ago, AlexR said: Broncos, Chargers and Raiders I believe it was a option from 70-72 You are correct, but they weren't that wide. I agree with @Achto that the story behind this modification helps tell it's story. Edited July 1 by 953 nut 2 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #19 Posted July 2 (edited) 2 hours ago, 953 nut said: The early ignition switches ( # 7262 )can be hard to find and rather expensive if you do find them. The wiring diagram below uses a reasonably priced 103990 ignition switch and a solenoid. @953 nut Thank you for the information. This was going to be my next question as for a alternative switch . Ive been looking for a 7262 and like you said they are quite expensive ,more than I’m willing to pay. I’ll go with your recommendation for the 103990 switch.I believe I may even have a spare solenoid laying around somewhere. Much appreciated Edited July 2 by Wheelhorse#1 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #20 Posted July 3 On 7/1/2026 at 5:34 PM, ebinmaine said: Looks like a good project. Do NOT use that seat bracket unless it can lock down. Ask me how I know...... Ditto on that Erick. Or Ben there done that. Years ago. Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #21 Posted July 11 (edited) I’m getting the 68 back together.I wired it up using a solenoid and a 103990 Ignition switch as suggested by @953 nut it was tight but I found a spot by the tower. I put on a new drive belt ,had to cobble together some fuel line wile I wait for replacement line. There is a outer bearing that should be replaced on the generator.It wines a bit even after greasing both bearings but is working fine. Today I’ll flush the trans and replace gear oil. The deck is ready I just have to sharpen the blades. I have to say the 68 commando has an interesting drive set up for the deck with the gears and belts but everything seems to be good.’ Shes running great with zero smoke . The intake valve is slightly out of speck and I’ll have to replace that too. But she’s running great let’s see if I can post a video IMG_2212.mov Edited July 11 by Wheelhorse#1 6 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #22 Posted July 11 (edited) Cut some grass today.Cut better than I thought it would. Deck is a bit noisy but I’m guessing it is just the nature of these old gear driven decks. Hard to believe that the original tires still hold air after all this time Edited July 11 by Wheelhorse#1 6 1 Share this post Link to post Share on other sites
sqrlgtr 3,925 #23 Posted July 12 5 hours ago, Wheelhorse#1 said: old gear driven decks. they are defiantly louder. 1 Share this post Link to post Share on other sites
Blaine 276 #24 Posted July 12 I just re-configured a 32” 64-65 Lawn Ranger gear drive to use on my 401 to replace the one i had been running for the last 10+ years that was pretty beat. I was amazed how quiet it is. I thought the belt was seriously slipping when i first engaged the pedal, but it was just that quiet. I use the red “tacky” grease on the gears. Check the cross shaft for axial play. It should be minimal. Maybe .020”- .025”. On my 702, when i bought it and finally got it to the point i could mow with it, i noticed it wasn’t cutting well on the one side. I found that the one cross shaft gear had a sheared woodruff key. Once i replaced the woodruff, the cross shaft wouldn’t turn. I found that the gear spinning freely on the shaft had smeared the shoulder of the shaft where the gear butts up against, so when the nut was tightened, it was pinching the bearing towers between the two gears. The shaft is 3/4” and the bore in the gear is 5/8”, so basically the gear rests up against a 1/16” shoulder on the shaft, so don’t over-tighten the nut or it can damage the shaft. I ended up making a .020” shim with a 5/8” i.d. to fit behind the gear. In hindsight, i could have made it .030”-.035” and shimmed out a bit more of the backlash at the gears also. I think there is a service bulletin on thicker thrust bearing washers for the blade shafts to minimize gear noise on some models also, but if you have excessive axial or radial play in the cross shaft bearings, i’d start there. If the gear nuts were over-torqued at some point, or a smeared woodruff, the shoulders on the cross shaft may be damaged, resulting in excessive axial play of the shaft which results in excessive backlash at the gears. Cross shaft tower bearings 1630-2RS Blade shaft needle bearings B1212 The threads in the aluminum(?) bearing towers on my old deck were in rough shape from numerous belt changes. I swapped out the bolts with longer ones and whatever combination of washers needed to grab ALL of the threads possible in the towers. Maybe inspect the cast housing closely for cracks also. I’ve cracked 3 of them over the last 28 years. They get really noisy when that happens. They break across these same two holes. I added some bolts that kept this one mowing for a few more years. The Lawn Ranger donor before, and after the Suburban linkage transplant. 1 1 1 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #25 Posted July 17 @BlaineThanks for the info and suggestions.I will look into these things a bit closer in the future. These early decks have a pretty interesting design for sure. Share this post Link to post Share on other sites
