1968Commando
Dash decal install
1968Commando
Hello everyone, I bought my wheel horse stickers probably a year ago anyways I put all the stickers on except the dash sticker… is it probably ruined now?? It’s a little wrinkled from the weather and humidity from sitting in the garage and such? Do I need a new one? Also how do you go about applying these properly without bubbles and cleanly
JCM
Back around the year 2000 I repainted this 1986  312-8 and installed OEM decals dry. Being older now I use either a small amount of Dawn dish shop mixed with water or my preferred method is Windex WITHOUT ammonia works very well. Patience helps a lot.  Good luck
Achto
Like suggested above, spray some soapy water on the dash first. Use a plastic body filler spreader or a credit card to help flatten the decal out on to the part. Always start in the middle of the decal and work towards the outside.
Racinbob
I believe you're talking about this style dash similar to the 500 Special I did.
Terry's decals are typically very easy and forgiving to apply but these dash decals might be the toughest. Make sure the surface is prepared very well. The metallic decal will show any imperfection. I primed, sanded and cleaned it like I was going to apply paint. Since this decal is so different from the others I started at the bottom and slowly worked my way up fitting it tight to the ridge across the center. The credit card thing works very well although I used an AARP card. :rolleyes:
  • Excellent 3
WHX??
I would just use the one you have. If it doesn't work out Terry will probably be more than happy to send another if it screws up. He's good about that.
1968Commando
Thank you, yes this is my dash. This it what it looks like right now.
Retired Wrencher
Bob I found out by cutting it in half helps a lot  to apply the decals. Also a slow peel back of the two parts. Just my :twocents-02cents:
WHX??
Your not the first guy I heard that from Wrencher.
Dan I noticed some funkyness going on with the dash on Radferd. Will get some pics.
Your biggest chore is going to be removing everything to get the dash on the work bench Commando. Then having to put it all back together. :scared-notify:
WHX??
So I don't what happened here. :confusion-shrug: Looks worse in sunlight and I'm sure what with @Achto's analness for prepping it was done proper.
Something else to watch for is don't rely on the D hole to keep the knob base from turning during tightening. I hate to tell you to clamp a vice grips on it. Will mar it for sure. Every one I have done did this you think I would have learned.
Possibly cut the decal out from under the knob with an exacto knife so it doesn't set on the decal???
Same with the four corner screws and switches. Use plastic washers underneath.
Looks like Dan cut the decal just above the black to silver transition.
Edited by WHX??
  • Sad 2
photorich1965
I hate doing decal work, being shaky and impatient ;-).  Always read the wet method was the way to do bigger graphics... but water and adhesive ?  Just sounded like a bad mix to me.  Finally tried it on my WH hood graphics and it was a game changer !  No more instant grab, or slightly crooked lines you just have to live with.  Nope, you can pull it up, reapply, and once you're happy a soft squeegee will remove the water and bubbles.  So yeah, try the Water and Dawn method :-).     Good luck !        Rich R
Retired Wrencher
The first one I
did not come out right. So the second one I cut it and it was a lot better that way. I also sanded it with fine sand paper to smooth surface. This made it easy.
Edited by Retired Wrencher
sqrlgtr
I think Terry sells them in two, maybe three pieces now, I know that doesn't help if you already have the one-piece style but thought I would mention it.
Retired Wrencher
That is good to no sqrlgtr:  Thanks.
1968Commando
Got it out.
1968Commando
What style is this one?
1968Commando
Is this clean enough?
sqrlgtr
looks like a one piece decal. I think he makes the decals in 3 separate pieces (for ease of applying) if ya want it that way but its been a while since I was on his web page.
1968Commando
Yeah I got these decals a year ago
