Fordiesel69
522xi - Starts 2sec then stalls
Fordiesel69
I was not operating it, but in the middle of a mow it shut off like someone turned the key.  Once we towed it back, it just starts and within 2 sec dies.  If I hold the key in the start position, magically it still runs.
Seat switch is good as I have parking brake fully set.  I jumped the switch just to be sure.  Oil level is at F.  Not sure how to check further.
gwest_ca
I don't know if all model years are the same or not.
Will guess at this one. Download the file and in it is a diagram for just the ignition. Easy to follow.
Handy Don
Posted (edited)
Deleted previous info. Misread the schematic...
Edited by Handy Don
JoeM
Make sure your red wire is hooked up the carb anti backfire solenoid and you can hear an audible click when turning it to the run position.
Bill D
34 minutes ago, Handy Don said:
Likely electrical and since it runs while being held in start (much to the dismay of the starter motor, I’m sure) I’d suspect the switch itself may be giving intermittent on the internal contact with the “I” terminal while in the Run position but being OK when in the Start position.
I’d begin by voltage checking the wiring starting at the “I” (ignition) terminal on the switch. It should have 12v when the key is in Run or Start positions--and be sure to wiggle the key while it’s in the Run position to see if that affects anything! I’d also carry the voltmeter around and once it stalls out, immediately (without touching ANYTHING ELSE) check for voltage at the “+” terminal on the coil. No voltage there means no spark and gives you a starting place to find out why!
Does the xi series have a powered ignition?  I thought those had a magneto?
Handy Don
You are correct. I saw an I terminal on the switch instead of the M and thought battery.
gwest_ca
They use a battery style ignition switch to power a kill relay to control the magneto ignition.
Handy Don
Elegant, especially since it permitted combining other safety switches in that circuit.
953 nut
Your charging system has a diode that feeds the fuel shut-off solenoid while the engine is running. The solenoid is fed directly from the key switch in the start position.
Take a look at the VIOLET colored wired from the charging system to the fuel solenoid and its diode.
953 nut
That system has been used by Wheel Horse for years, primarily on Briggs powered B & C series tractors.
Here is a thread I did a few years ago that shows how simple it is.
Bill D
Posted (edited)
That makes more sense.   Thanks for the clarification. Maybe change the kill relay.
Edited by Bill D
  • Confused 1
953 nut
I have helped several people with this "2 second run time" problem and in each case it was the wire or diode from the stator to the fuel solenoid. Kill relay couldn't do the 2 second trick but in the START position the fuel solenoid will open long enough to allow a couple seconds worth of fule into the carb.
The fact that holding the key in the start position allows the engine to run tells you the fuel solenoid works and the diode on that wire prevents back-feeding the ignition switch and if the kill relay was not working there would be no ignition.
Fordiesel69
So I tested it last night and I have no voltage on fuel solenoid while in run position, and 11.93 vdc when cranking.
Where do I look next.
gwest_ca
The purple wire should have power with the ignition in the RUN position - engine does not need to be running.
There is a fuse in that wire so check that. You should have power both sides of the fuse. If not check connections at the ignition switch and possibly ignition switch failure. This circuit also charges your battery.
