Fordiesel69 272 #1 Posted June 30 I was not operating it, but in the middle of a mow it shut off like someone turned the key. Once we towed it back, it just starts and within 2 sec dies. If I hold the key in the start position, magically it still runs. Seat switch is good as I have parking brake fully set. I jumped the switch just to be sure. Oil level is at F. Not sure how to check further. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #2 Posted June 30 I don't know if all model years are the same or not. Will guess at this one. Download the file and in it is a diagram for just the ignition. Easy to follow. Share this post Link to post Share on other sites
Handy Don 17,474 #3 Posted June 30 (edited) Deleted previous info. Misread the schematic... Edited June 30 by Handy Don Share this post Link to post Share on other sites
JoeM 10,268 #4 Posted June 30 Make sure your red wire is hooked up the carb anti backfire solenoid and you can hear an audible click when turning it to the run position. 1 Share this post Link to post Share on other sites
Bill D 3,156 #5 Posted June 30 34 minutes ago, Handy Don said: Likely electrical and since it runs while being held in start (much to the dismay of the starter motor, I’m sure) I’d suspect the switch itself may be giving intermittent on the internal contact with the “I” terminal while in the Run position but being OK when in the Start position. I’d begin by voltage checking the wiring starting at the “I” (ignition) terminal on the switch. It should have 12v when the key is in Run or Start positions--and be sure to wiggle the key while it’s in the Run position to see if that affects anything! I’d also carry the voltmeter around and once it stalls out, immediately (without touching ANYTHING ELSE) check for voltage at the “+” terminal on the coil. No voltage there means no spark and gives you a starting place to find out why! Does the xi series have a powered ignition? I thought those had a magneto? 1 Share this post Link to post Share on other sites
Handy Don 17,474 #6 Posted June 30 26 minutes ago, Bill D said: Does the xi series have a powered ignition? I thought those had a magneto? You are correct. I saw an I terminal on the switch instead of the M and thought battery. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #7 Posted June 30 They use a battery style ignition switch to power a kill relay to control the magneto ignition. 2 Share this post Link to post Share on other sites
Handy Don 17,474 #8 Posted June 30 3 minutes ago, gwest_ca said: They use a battery style ignition switch to power a kill relay to control the magneto ignition. Elegant, especially since it permitted combining other safety switches in that circuit. Share this post Link to post Share on other sites
953 nut 69,333 #9 Posted June 30 Your charging system has a diode that feeds the fuel shut-off solenoid while the engine is running. The solenoid is fed directly from the key switch in the start position. Take a look at the VIOLET colored wired from the charging system to the fuel solenoid and its diode. Share this post Link to post Share on other sites
953 nut 69,333 #10 Posted June 30 29 minutes ago, Handy Don said: Elegant, especially since it permitted combining other safety switches in that circuit. That system has been used by Wheel Horse for years, primarily on Briggs powered B & C series tractors. Here is a thread I did a few years ago that shows how simple it is. Share this post Link to post Share on other sites
Bill D 3,156 #11 Posted June 30 (edited) 2 hours ago, gwest_ca said: They use a battery style ignition switch to power a kill relay to control the magneto ignition. That makes more sense. Thanks for the clarification. Maybe change the kill relay. Edited June 30 by Bill D 1 Share this post Link to post Share on other sites
953 nut 69,333 #12 Posted June 30 1 hour ago, Bill D said: Maybe change the kill relay. I have helped several people with this "2 second run time" problem and in each case it was the wire or diode from the stator to the fuel solenoid. Kill relay couldn't do the 2 second trick but in the START position the fuel solenoid will open long enough to allow a couple seconds worth of fule into the carb. 9 hours ago, Fordiesel69 said: If I hold the key in the start position, magically it still runs. The fact that holding the key in the start position allows the engine to run tells you the fuel solenoid works and the diode on that wire prevents back-feeding the ignition switch and if the kill relay was not working there would be no ignition. Share this post Link to post Share on other sites
Fordiesel69 272 #13 Posted July 16 So I tested it last night and I have no voltage on fuel solenoid while in run position, and 11.93 vdc when cranking. Where do I look next. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #14 Posted July 16 The purple wire should have power with the ignition in the RUN position - engine does not need to be running. There is a fuse in that wire so check that. You should have power both sides of the fuse. If not check connections at the ignition switch and possibly ignition switch failure. This circuit also charges your battery. Share this post Link to post Share on other sites
OoPEZoO 609 #15 Posted July 17 definitely check connections.....and then check them again. I had issues with my Xi last year and chased my tail for a week trying to figure out what was wrong. Turns out the previous owner did a marginal job at bypassing the seat switch and anytime there was enough vibration it would shut off. Not necessarily your issue, just an example. These tractors are getting some age on them and its very easy to overlook a little corrosion inside one of the shrouded connectors. There is very little "stuff" on that purple wire, but what was mentioned is correct. In the RUN position, you should always have battery voltage at the fuel solenoid. If not, start working backwards towards the ignition switch. 1 Share this post Link to post Share on other sites
953 nut 69,333 #16 Posted July 17 On 7/16/2026 at 3:45 PM, gwest_ca said: purple wire should have power with the ignition in the RUN position - engine does not need to be running. This is true IF the diode on the purple (Violet) wire to the fuel solenoid is good. Share this post Link to post Share on other sites
