eric8 7 #1 Posted Sunday at 02:34 PM Regarding the engine wiring harness that goes up the dipstick tube. I found my tractor to have it going up the tube and over the black heat exhaust heat shield (which seems safer but doesn't look as neat). I've seen several pics like the attached that show it going up the tube and appearing to disappear under the exhaust heat shield, which would inevitably sandwich it between the exhaust pipe and cylinder head? Which is the correct routing from the factory? Share this post Link to post Share on other sites
peter lena 9,924 #2 Posted Sunday at 04:15 PM @eric8 https://www.google.com/search?q=wheel+horse+belt+guard+vent+hiles&rlz=1C1CHBF_enUS866US866&oq=wheel+horse++belt++guard+vent+hiles+&gs_lcrp=EgZj just a suggestion for heat discharge enhancement , why not RE ROUTE / ELIMINATE CONSISTANT PROBLEM ? cable wrap to a cooler / friendlier area ? local metal shop would make quick work of that belt guard furnace . lots of related picture ideas . good opportunity , pete Share this post Link to post Share on other sites
eric8 7 #3 Posted Sunday at 05:48 PM 1 hour ago, peter lena said: @eric8 https://www.google.com/search?q=wheel+horse+belt+guard+vent+hiles&rlz=1C1CHBF_enUS866US866&oq=wheel+horse++belt++guard+vent+hiles+&gs_lcrp=EgZj just a suggestion for heat discharge enhancement , why not RE ROUTE / ELIMINATE CONSISTANT PROBLEM ? cable wrap to a cooler / friendlier area ? local metal shop would make quick work of that belt guard furnace . lots of related picture ideas . good opportunity , pete i'm not sure where the confusion came from where you thought I was referring to wiring going behind the belt guard? I'm talking about the wiring harness that goes up the dipstick tube and under the black engine tin in the photo. Does it go under the engine tin as shown in the photo or above it? Share this post Link to post Share on other sites
lynnmor 8,870 #4 Posted Sunday at 06:51 PM Mine are squished under the intake manifold. 2 Share this post Link to post Share on other sites
Bill D 2,970 #5 Posted Sunday at 06:53 PM 1 minute ago, lynnmor said: Mine are squished under the intake manifold. Same on my three Onans. That is the factory wiring. 2 Share this post Link to post Share on other sites
eric8 7 #6 Posted Sunday at 07:12 PM Appreciate it gents! Share this post Link to post Share on other sites
sqrlgtr 3,099 #7 Posted Sunday at 07:19 PM 27 minutes ago, lynnmor said: Mine are squished under the intake manifold. 25 minutes ago, Bill D said: Same on my three Onans. That is the factory wiring. same on my 2 520's 2 Share this post Link to post Share on other sites
peter lena 9,924 #8 Posted Sunday at 07:39 PM @eric8 that belt guard is like a hot air furnace , if its vented , it greatly ENHANCES ENGINE HEAT DISCHARGE , that entire set up is known for heat related wiring issues , yo are looking right at the reason / cause of issues . sorry for suggesting , pete Share this post Link to post Share on other sites
eric8 7 #9 Posted Sunday at 07:56 PM 14 minutes ago, peter lena said: @eric8 that belt guard is like a hot air furnace , if its vented , it greatly ENHANCES ENGINE HEAT DISCHARGE , that entire set up is known for heat related wiring issues , yo are looking right at the reason / cause of issues . sorry for suggesting , pete Possibly a good upgrade for the future. Glad I took this thing apart. I found grass clippings stuck under the engine tin which definitely wasn’t helping matters Share this post Link to post Share on other sites
eric8 7 #10 Posted Sunday at 09:46 PM @lynnmor @BillD @sqrlgtr Can I also get a poll on throttle cable routing? Mine are routed like this guy's, down the right side of the engine following the positive battery cable in the hold down clamps. Now I just ran across a photo on here of the throttle cable going behind the rear cylinder, under the left side of the engine, and then curling up? Share this post Link to post Share on other sites
Bill D 2,970 #11 Posted Monday at 12:18 AM I'll have to look at mine. I can't remember. 1 Share this post Link to post Share on other sites
sqrlgtr 3,099 #12 Posted Monday at 02:24 AM 4 hours ago, eric8 said: Can I also get a poll on throttle cable routing? will try and get a pic tomorrow but I believe mine comes from the other side under fan blower housing and up. 1 Share this post Link to post Share on other sites
eric8 7 #13 Posted Wednesday at 07:54 PM Anyone ever look at their throttle cable routing? Share this post Link to post Share on other sites
sqrlgtr 3,099 #14 Posted Wednesday at 09:28 PM I had forgot about u. Here is a couple pics of mine hope this helps. Share this post Link to post Share on other sites
sqrlgtr 3,099 #15 Posted Wednesday at 09:30 PM A couple more just for prosterity 1 Share this post Link to post Share on other sites
eric8 7 #16 Posted Wednesday at 10:00 PM (edited) Thanks @sqrlgtr! Looks like mine was all wrong. My throttle cable clip on the blower housing that yours has is missing in action too. I’m gonna bug you one more time. Does the cable go through the cable holder on the right front of the hoodstand? Or is that holder just for the positive battery cable? Edited Wednesday at 10:00 PM by eric8 Share this post Link to post Share on other sites
sqrlgtr 3,099 #17 Posted Wednesday at 11:44 PM 1 hour ago, eric8 said: Does the cable go through the cable holder on the right front of the hoodstand? Or is that holder just for the positive battery cable? @eric8 I'm not sure and the tractor is at my other place; I tried to see on some of the pics I have but cannot tell. I will try and check tomorrow for ya but I don't see why it would hurt to run it through the clip if it doesn't put cable in a bind. You know the more I think about it I believe mine runs to other side of engine before it starts down if that makes sense, but I will try and check it out tomorrow. Share this post Link to post Share on other sites
eric8 7 #18 Posted yesterday at 01:17 AM Ok sounds good Share this post Link to post Share on other sites
sqrlgtr 3,099 #19 Posted 21 hours ago 23 hours ago, eric8 said: Ok sounds good hadn't forgot about ya just been in hay field all week will try my best to get pics in morning. Share this post Link to post Share on other sites
sqrlgtr 3,099 #21 Posted 8 hours ago Here is a few pics of the way my throttle cable is routed. Share this post Link to post Share on other sites
parsonsponyz 366 #22 Posted 8 hours ago I have a factory fresh 520 that's untouched and that is how the routing for the throttle is handled. Share this post Link to post Share on other sites
eric8 7 #23 Posted 5 hours ago (edited) Thanks @sqrlgtr for getting those and @parsonsponyz for confirming your setup. I’ll be correctly re-routing mine once I find a blower housing wire clip for the throttle cable Edited 5 hours ago by eric8 Share this post Link to post Share on other sites
