eric8 7 #1 Posted 6 hours ago Regarding the engine wiring harness that goes up the dipstick tube. I found my tractor to have it going up the tube and over the black heat exhaust heat shield (which seems safer but doesn't look as neat). I've seen several pics like the attached that show it going up the tube and appearing to disappear under the exhaust heat shield, which would inevitably sandwich it between the exhaust pipe and cylinder head? Which is the correct routing from the factory? Share this post Link to post Share on other sites
peter lena 9,913 #2 Posted 4 hours ago @eric8 https://www.google.com/search?q=wheel+horse+belt+guard+vent+hiles&rlz=1C1CHBF_enUS866US866&oq=wheel+horse++belt++guard+vent+hiles+&gs_lcrp=EgZj just a suggestion for heat discharge enhancement , why not RE ROUTE / ELIMINATE CONSISTANT PROBLEM ? cable wrap to a cooler / friendlier area ? local metal shop would make quick work of that belt guard furnace . lots of related picture ideas . good opportunity , pete Share this post Link to post Share on other sites
eric8 7 #3 Posted 3 hours ago 1 hour ago, peter lena said: @eric8 https://www.google.com/search?q=wheel+horse+belt+guard+vent+hiles&rlz=1C1CHBF_enUS866US866&oq=wheel+horse++belt++guard+vent+hiles+&gs_lcrp=EgZj just a suggestion for heat discharge enhancement , why not RE ROUTE / ELIMINATE CONSISTANT PROBLEM ? cable wrap to a cooler / friendlier area ? local metal shop would make quick work of that belt guard furnace . lots of related picture ideas . good opportunity , pete i'm not sure where the confusion came from where you thought I was referring to wiring going behind the belt guard? I'm talking about the wiring harness that goes up the dipstick tube and under the black engine tin in the photo. Does it go under the engine tin as shown in the photo or above it? Share this post Link to post Share on other sites
lynnmor 8,858 #4 Posted 2 hours ago Mine are squished under the intake manifold. 2 Share this post Link to post Share on other sites
Bill D 2,946 #5 Posted 2 hours ago 1 minute ago, lynnmor said: Mine are squished under the intake manifold. Same on my three Onans. That is the factory wiring. 2 Share this post Link to post Share on other sites
sqrlgtr 3,065 #7 Posted 1 hour ago 27 minutes ago, lynnmor said: Mine are squished under the intake manifold. 25 minutes ago, Bill D said: Same on my three Onans. That is the factory wiring. same on my 2 520's 2 Share this post Link to post Share on other sites
peter lena 9,913 #8 Posted 1 hour ago @eric8 that belt guard is like a hot air furnace , if its vented , it greatly ENHANCES ENGINE HEAT DISCHARGE , that entire set up is known for heat related wiring issues , yo are looking right at the reason / cause of issues . sorry for suggesting , pete Share this post Link to post Share on other sites
eric8 7 #9 Posted 1 hour ago 14 minutes ago, peter lena said: @eric8 that belt guard is like a hot air furnace , if its vented , it greatly ENHANCES ENGINE HEAT DISCHARGE , that entire set up is known for heat related wiring issues , yo are looking right at the reason / cause of issues . sorry for suggesting , pete Possibly a good upgrade for the future. Glad I took this thing apart. I found grass clippings stuck under the engine tin which definitely wasn’t helping matters Share this post Link to post Share on other sites
