Lane Ranger
A most unusual Attachment!
Lane Ranger
This is a new one on me!
I have never seen a homemade big saw attachment made like this before!
This is being sold with a Wheel Horse 8 hp tractor in southern Indiana.
The person who made this saw a need that could be fulfilled with his Wheel Horse!
The big saw blade frame looks substantial and appears to have a pulley setup similar to the tiller setup!
I had to post this as this is probably second to the chicken feather plucker attachment as the most innovative thing I’ve ever seen on a Wheel Horse!
peter lena
@Lane Ranger  think as long as the related , blade rotational set up is  smooth free and easy , it would definitely work , most of the stuff I see , is brutal neglect , COLLECTIVE DRAG  , thats the killer  , that led me quickly to  related " lubrication failure / breakdown ". the commonality of  lube failure  is like glue , pretty simple  fix , you want a lubricant that  exceeds, original , PENNY PINCING  , set ups . every one of  my removable  wide bearing side shields , is easily  removed , small flat pocket screwdriver  / smallest flat  putty knife , wipe out , carb clean flush , lucas x tra hd , green chassis grease  , 550 deg flash /drop point , polyurea ?  anti sling , assures staying with it  , every spindle and related pto , mule  drive set up , also VERIFIED   FUNCTIONAL DETAILING , try/ test / try . issues ? adjust /  verify . my pto lever set up is effortless in movement  / no belt scream  or  clutch wear . repetitive problem , shows you the way to change, use this mind set on  one eliminated issue  , it becomes  home base . pete
JoeM
A good strong WH and premium medical insurance required!
Like wooden frame on top. Must have been throwing dust up, hence the guard!
Lane Ranger
no osha review for sure!  Sawdust must have been flying with this!
CCW
I have worked with a lot of saws over the past 70 odd years and I don’t think I would touch this one.
