FLtractor 223 #1 Posted June 23 Evening, While researching and learning about Kohler engines, I came across this, unaware that Kohler still made small engines. anyone have experience with this one or similar modern Kohler engines? How do they compare say to those harbor freight predators and or The genuine Honda 200s those are based off of? https://www.smallenginewarehouse.com/sh270-3142?setCurrencyId=1&sku=SH270-3142&utm_source=google&utm_medium=cpc&utm_campaign=22419493833&utm_content=&utm_term=&utm_source=google&utm_medium=cpc&utm_campaign=pmaxbriggs&utm_content=&utm_term=&gad_source=1&gad_campaignid=22429555384&gclid=EAIaIQobChMIgt293ZmclQMVnXV_AB3owjxMEAQYASABEgIrivD_BwE Share this post Link to post Share on other sites
pfrederi 21,146 #2 Posted June 23 Just stick with your K181 The shaft on your linked engine is to small and too short. I know you are trying to learn but stay focused on what you have. 3 2 Share this post Link to post Share on other sites
kpinnc 18,957 #3 Posted June 23 2 hours ago, pfrederi said: Just stick with your K181 The shaft on your linked engine is to small and too short. I know you are trying to learn but stay focused on what you have. Agreed. Plus the K181 has ball bearings at both ends of the crank. No comparison whatsoever. 3 1 Share this post Link to post Share on other sites
953 nut 69,242 #4 Posted June 23 9 hours ago, pfrederi said: stay focused That is the key component that will lead to learning. 1 Share this post Link to post Share on other sites
clueless 3,439 #5 Posted June 23 13 hours ago, FLtractor said: Evening, While researching and learning about Kohler engines, I came across this, unaware that Kohler still made small engines. anyone have experience with this one or similar modern Kohler engines? How do they compare say to those harbor freight predators and or The genuine Honda 200s those are based off of? https://www.smallenginewarehouse.com/sh270-3142?setCurrencyId=1&sku=SH270-3142&utm_source=google&utm_medium=cpc&utm_campaign=22419493833&utm_content=&utm_term=&utm_source=google&utm_medium=cpc&utm_campaign=pmaxbriggs&utm_content=&utm_term=&gad_source=1&gad_campaignid=22429555384&gclid=EAIaIQobChMIgt293ZmclQMVnXV_AB3owjxMEAQYASABEgIrivD_BwE Neither the newer Kohler or the Predator compare the the one you have, get it running and you'll be better off, "Just Do It". Share this post Link to post Share on other sites
FLtractor 223 #6 Posted June 23 3 hours ago, clueless said: Neither the newer Kohler or the Predator compare the the one you have, get it running and you'll be better off, "Just Do It". What’s makes the original so much better? American made.. thicker block? Better components? Share this post Link to post Share on other sites
pfrederi 21,146 #7 Posted June 23 (edited) Cast Iron Block real steel camshaft gears ball bearings on the crankshaft Edit: Check back in 65 years see how many of the predators are still running Edited June 23 by pfrederi 2 1 Share this post Link to post Share on other sites
squonk 48,110 #8 Posted June 23 Actually the Predators are pretty decent now. Share this post Link to post Share on other sites
FLtractor 223 #9 Posted June 23 52 minutes ago, pfrederi said: Cast Iron Block real steel camshaft gears ball bearings on the crankshaft Edit: Check back in 65 years see how many of the predators are still running Thank you for telling me what’s inside that makes it better instead of just it’s a vintage Kohler, use it fix it- since this being a Wheelhorse forum. is this Carrol stream engine just another same engine different name then predator ect? https://carrollstream.com/212cc-6-half-hp-electric-start-gas-engine/?srsltid=AfmBOopL29h8Yar7T5n6a17uzOMzA-NGMQg9gDro17IhxWtzxTaEnsCu Share this post Link to post Share on other sites
clueless 3,439 #10 Posted June 24 17 hours ago, FLtractor said: What’s makes the original so much better? American made.. thicker block? Better components? all the above 2 Share this post Link to post Share on other sites
lynnmor 9,039 #11 Posted June 24 Keep in mind that the Kohler name is history. https://www.rehlko.com/kohler-energy-is-now-rehlko Share this post Link to post Share on other sites
Retired Wrencher 6,986 #12 Posted June 25 On 6/22/2026 at 10:32 PM, pfrederi said: Just stick with your K181 The shaft on your linked engine is to small and too short. I know you are trying to learn but stay focused on what you have. Don’t get over whelmed. Stay focused on the job at hand. This will pay you back tenfold. Share this post Link to post Share on other sites
bds1984 1,519 #13 Posted June 26 On 6/23/2026 at 3:18 PM, FLtractor said: Thank you for telling me what’s inside that makes it better instead of just it’s a vintage Kohler, use it fix it- since this being a Wheelhorse forum. is this Carrol stream engine just another same engine different name then predator ect? https://carrollstream.com/212cc-6-half-hp-electric-start-gas-engine/?srsltid=AfmBOopL29h8Yar7T5n6a17uzOMzA-NGMQg9gDro17IhxWtzxTaEnsCu Pretty much any generic OHV engine sold in the last two decades is a clone of the Honda GX series engine. If you are dead set on replacing any engine and don't care about it being original, just go to Harbor Freight, they're all pretty much the same basic design with similar power output. I have used a few of the clone engines over the years but only on equipment that I couldn't find an original style engine or the cost of rebuilding was too much; it was hard to beat the $99 price tag years ago to replace an engine on a seldom used rototiller. If you can keep the original Kohler engine going, that's what I'd aim for, but I understand that everyone and every situation has its limitations. There is a lot of knowledge here on this forum and willingness to talk you through. Share this post Link to post Share on other sites
FLtractor 223 #14 Posted June 26 33 minutes ago, bds1984 said: Pretty much any generic OHV engine sold in the last two decades is a clone of the Honda GX series engine. If you are dead set on replacing any engine and don't care about it being original, just go to Harbor Freight, they're all pretty much the same basic design with similar power output. I have used a few of the clone engines over the years but only on equipment that I couldn't find an original style engine or the cost of rebuilding was too much; it was hard to beat the $99 price tag years ago to replace an engine on a seldom used rototiller. If you can keep the original Kohler engine going, that's what I'd aim for, but I understand that everyone and every situation has its limitations. There is a lot of knowledge here on this forum and willingness to talk you through. That’s interesting to learn about most recently decades copying the Honda GX. I got my K181 running driving. Any idea how much I’d have to pay for it to be rebuilt if I did need it in future? Any idea on average time frame with parts available these days? Share this post Link to post Share on other sites
