John c 223 #1 Posted June 18 C101 with a K241 So I transplanted another condenser from a different engine, It fired right up I thought all was good was gonna fine tune the carb as I was putting the machine back together, and a few minutes into it, the engine dies, no spark. Won't run with or without the condenser in the circuit. I don't have anymore condensers to try at the moment, I have a couple ordered though Now the story that leads up to this is I'd found an out barn find close by and was going to make a grass cutter out of it. I put new spark plug, coil, points and condenser on it as part of the refurbishment project, ran it about an hour, it dies. I bring it back into the shop going over it to try and figure out what happened, cranking the engine I see sparks arcing between the engine block and belt cover right by the PTO, that leads me to finding the chassis ground jumper on the shaker plate mount broken, also decided to replace the rubber mounts while I was in it, I used the machined aluminum style, and also replaced the ground wire. It still wouldn't start, used a transplant condenser and it rans only a few minutes. Is it possible the engine mount swap somehow effects this, I can't see how, but ? Or was it the low budget amazon brand X tune up parts releasing gremlins in it ? Share this post Link to post Share on other sites
8ntruck 9,296 #2 Posted June 18 Take a look at the points. One of the functions of the condenser is to prevent the points from arcing when they open. A bad condenser encourages the points to burn. 1 Share this post Link to post Share on other sites
WHX?? 58,125 #3 Posted June 18 1 hour ago, John c said: possible the engine mount swap somehow effects this No but the motor still needs a good ground. Don't rely on solid mounts alone to accomplish that. Kudos on the decision to go to solid mounts tho. Check for spark and go after the coil (make sure it's getting 12 volts) Clean & reset the points and always have a new condenser on the shelf. Never hurts to have a spare coil on the shelf either. 1 Share this post Link to post Share on other sites
ri702bill 13,064 #4 Posted June 18 25 minutes ago, WHX?? said: Never hurts to have a spare coil on the shelf either. A known good coil at that.... Share this post Link to post Share on other sites
WHX?? 58,125 #5 Posted June 18 1 minute ago, ri702bill said: A known good brand new coil at that.... Course that don't mean much these days. Share this post Link to post Share on other sites
wallfish 20,618 #6 Posted June 19 Guessing that coil does NOT have an internal resistor built into it. That will burn out the points and or the condenser 3 2 Share this post Link to post Share on other sites
WHX?? 58,125 #7 Posted June 19 (edited) 12 minutes ago, wallfish said: does NOT have an internal resistor Strange thing there 'Fish when I got my 1045 it had a coil on it clearly labeled on it "use external resistor" and it always started & ran great. I swapped it out for supposedly the internal kind but ever since then hard starting. Runs good just hard to no start. Stock non ACR big block. Edited June 19 by WHX?? 1 Share this post Link to post Share on other sites
Achto 32,693 #8 Posted June 19 26 minutes ago, WHX?? said: Strange thing there 'Fish when I got my 1045 it had a coil on it clearly labeled on it "use external resistor" and it always started & ran great. I swapped it out for supposedly the internal kind but ever since then hard starting. On the other hand, remember Busty's first year at Pickett Jim ?? Would run fine for a while & then it would fall on its face. Ran fine with the voltage regulator unplugged. We ran to town & got a new internal resistor coil and it ran perfect even with the regulator plugged in. If I remember right the resistor had failed on the coil that was in it. 1 Share this post Link to post Share on other sites
John c 223 #9 Posted June 19 2 hours ago, ri702bill said: A known good brand new coil at that.... Course that don't mean much these days. That's my thought exactly, the points, coil and condenser were all in the same "kit" and now I don't trust any of it. I've got a rotary brand condenser, and a set of kolher brand points inbound now, I need to find a decent quality coil now. 1 Share this post Link to post Share on other sites
953 nut 69,303 #10 Posted June 19 Is your condenser connected to the "-" side of the ignition coil along with the points? This drawing was done by @Save Old Iron many years ago, good for visual learners. 2 Share this post Link to post Share on other sites
ebinmaine 80,695 #11 Posted June 19 23 hours ago, John c said: I put new spark plug, coil, points and condenser on it Why the new coil? Is the old one verified bad? Share this post Link to post Share on other sites
John c 223 #12 Posted June 20 yes the condenser is landed on the "-" terminal on the coil along with points lead. The old coil....I never gave it any thought I assumed the old coil probably OK, but the machine still had what looked like all it's original ancillary equipment, so I was refreshing things that deteriorate, fuel lines filters, fluids, repairs as needed, waking it up in a sense. Share this post Link to post Share on other sites
ebinmaine 80,695 #13 Posted June 20 8 hours ago, John c said: yes the condenser is landed on the "-" terminal on the coil along with points lead. The old coil....I never gave it any thought I assumed the old coil probably OK, but the machine still had what looked like all it's original ancillary equipment, so I was refreshing things that deteriorate, fuel lines filters, fluids, repairs as needed, waking it up in a sense. We run coils that are 50 or 60 years young without any issues. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #14 Posted June 20 (edited) I would test your old coil.. Note secondary should read 6000 to 10000 ohms Edited June 20 by pfrederi 1 Share this post Link to post Share on other sites
John c 223 #15 Posted June 20 I'm learning about battery ignition systems these last couple of weeks, until now everything has been magneto powered systems for me Share this post Link to post Share on other sites
John c 223 #16 Posted June 20 Paul, what is that spark checker thing shown plugged into the plug wire terminal Share this post Link to post Share on other sites
John c 223 #17 Posted June 20 (edited) how can you tell if a coil needs an external resistor or not ? and then if it does, how do you determine what size to use, both ohms and watts ratings Edited June 20 by John c Share this post Link to post Share on other sites
pfrederi 21,150 #18 Posted June 20 1 minute ago, John c said: how can you tell if a coil needs an external resistor or not ? Kohler Coils had internal resisters usually marked as such. Not my picture but any spark tester can be used in that test. I use the cheap neon one for the test. The B&S tester is better but harder to use in this test Share this post Link to post Share on other sites
953 nut 69,303 #19 Posted June 20 (edited) 48 minutes ago, John c said: how can you tell if a coil needs an external resistor or not ? and then if it does, how do you determine what size to use, both ohms and watts ratings If you do the resistance check on the primary windings and it reads 1 ohm to 1.5 ohms then you need an external resistor. Until 1973 when Chrysler went to electronic ignition they had an external ballast resistor mounted on the firewall. Ford and GM had their resistors in the wiring harness. You should be able to buy a Chrysler resistor at a good auto parts store or on line IF you need one. Edited June 20 by 953 nut fat finger 1 Share this post Link to post Share on other sites
pfrederi 21,150 #20 Posted June 20 If yo do get an external resister be careful where you mount it...they get hot and they do not like to get wet. 1 1 Share this post Link to post Share on other sites
John c 223 #21 Posted June 20 reads 1 ohm to 1.5 ohms then you need an external resistor. The drawing above shows primary winding reading 3-5 ohms, does that reading indicate an internal resistor is there? I've ordered me a coil with an external resistor, just be sure After school and before the air force, I worked in an auto parts store, I remember the Chrysler ballast resistors, that was in a time before advance, O'Rielly's, and the other chain stores, there was NAPA, and the independents. I knew some guys that drove mopars, they'd keep spares in the glovebox. Share this post Link to post Share on other sites
953 nut 69,303 #22 Posted June 20 1 hour ago, John c said: drawing above shows primary winding reading 3-5 ohms, does that reading indicate an internal resistor is there? YES 1 hour ago, John c said: I knew some guys that drove mopars, they'd keep spares in the glovebox. I was one of the many people who did that. Share this post Link to post Share on other sites
John c 223 #23 Posted June 20 So is there any simple tests or readings to determine if a condensor.....can still condense ? Share this post Link to post Share on other sites
pfrederi 21,150 #24 Posted June 21 1 hour ago, John c said: So is there any simple tests or readings to determine if a condensor.....can still condense ? Not really I believe it takes special equipment. Disconnect it if tractor starts running then denser was bad. 1 1 Share this post Link to post Share on other sites
Bar Nuthin 3,234 #25 Posted June 21 14 hours ago, John c said: how can you tell if a coil needs an external resistor or not ? In my case, I made the determination after I fried the third set of points! Plus, the coil would get REALLY hot! That's when I joined Red Square and learned that I needed a coil with an internal resistor. Now I test them with a multimeter and check for resistance above 3.0 ohm I've bought 2 tractors now, that had the wrong coils on them. 1 Share this post Link to post Share on other sites
