River Rat
Belt number for the Mule Drive on a C145A (1984)
River Rat
I am looking for the Wheel Horse part number for the Mule Drive belt on my 1984 C145A 11-14KE01. I believe it is 102742. The old one is stretched quite a bit and not sure the outside length. possibly 1/2 by 103 in? 48 inch mower.
Any help is appreciated!
gwest_ca
Click on the fuzzy picture in the link. The belts are listed on the page that comes up. May not be the exact deck you have but the belts will be the same.
953 nut
:WRS:
The deck belt for a 48" side discharge is a 102742 which is 1/2"  X  103"     Many of us are having good luck with Tractor Supply Kevlar belts, in your case it will be a 1/2"  X  103"  and cost about $ 30.00.
  • Similar Content
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • ryobi.warrior
      By ryobi.warrior
      The belt on my Wheel Horse 314-8 mower deck (05-37SC01) appears to be contacting the deck bracket between the spindle pulleys. I am a novice when it comes to Wheel Horse maintenance (at best), but this does not seem correct.
      I recently inherited this Wheel Horse, so I do not know the maintenance history. Unfortunately, the mechanic who previously worked on it was a no-show for a scheduled maintenance visit.
      Any advice on how to address this? Thanks in advance... this seems like a great forum and I'm looking forward to spending time here!
      Photos (please forgive the dirt and grime, I plan to clean it up!): https://imgur.com/a/4PknZuJ
    • seven
      By seven
      Does anyone know what size belt is required for the rear mounted tiller off of a charger 12
    • JackHorse
      By JackHorse
      Hi Guys, Had a random occurrence this week. Mowing along with my C85 eight speed in 1 low (grass was thick and wet), went to depress clutch and the drive belt jumped off the idler. I've had this tractor 3 years and it's been working great.  The belt itself looks good except the top of it was a bit chewed up in a short section which I believe happened after it came off.  I put the belt back on and continued to mow with no further issue.  Any ideas as to why this would happen or adjustments I might need to make to prevent another incident? Thanks
    • chsteinke44
      By chsteinke44
      i need help finding the right size drive belt for my 212-h wheel horse and the diagram for installing the belt.   i got the tractor from my wifes grampa and cant find the diagram for it or a replacement belt for it.  the id tag is 3212be01  46590
      the belt i need is the motor to transmition
