adsm08 5,145 #26 Posted June 18 On 6/17/2026 at 12:54 PM, FLtractor said: How do I verify the gen starter working properly and the dash light ? Turn the key on without cranking the engine. If the light works it will be on. Share this post Link to post Share on other sites
FLtractor 223 #27 Posted June 18 28 minutes ago, adsm08 said: Turn the key on without cranking the engine. If the light works it will be on. Sorry for confusion of a question… what I ment to ask is … how do I know if starter generator itself is working properly … and if it’s not.. what does it cost usually to have rebuilt (told before as with engine best to have orginal rebuilt or repaired instead of replacing) Share this post Link to post Share on other sites
pfrederi 21,150 #28 Posted June 18 (edited) 37 minutes ago, FLtractor said: Sorry for confusion of a question… what I ment to ask is … how do I know if starter generator itself is working properly … and if it’s not.. what does it cost usually to have rebuilt (told before as with engine best to have orginal rebuilt or repaired instead of replacing) It is a little hard to follow your issues If you can start the engine and it runs then we could pursue the red light. if it will not crank or run then forget about the red light until we resolve the starting issues,does the engine start and run? Edited June 18 by pfrederi 1 Share this post Link to post Share on other sites
adsm08 5,145 #29 Posted June 18 24 minutes ago, pfrederi said: It is a little hard to follow your issues If you can start the engine and it runs then we could pursue the red light. if it will not crank or run then forget about the red light until we resolve the starting issues,does the engine start and run? @FLtractortake a deep breath, control the ADHD, and slow down. You need to tackle one issue at a time, and the fact that you keep trying to go after all of them at once is why your issues seem so large. You need the engine to run before you can assess the generator. If it cranks that is a good sign. There is a set of contacts you can jump momentarily inside the regulator and it will make it crank, cycle the key to the start position and back off again to make it stop. I'll get a picture later. 1 Share this post Link to post Share on other sites
FLtractor 223 #30 Posted June 19 6 hours ago, pfrederi said: It is a little hard to follow your issues If you can start the engine and it runs then we could pursue the red light. if it will not crank or run then forget about the red light until we resolve the starting issues,does the engine start and run? It will crank.. but still diagnosing the run part.. will have to wait till Sunday to do the squirt fuel into carb while turn key to see if it fires and ignites temporarily. 1 Share this post Link to post Share on other sites
FLtractor 223 #31 Posted June 19 6 hours ago, adsm08 said: @FLtractortake a deep breath, control the ADHD, and slow down. You need to tackle one issue at a time, and the fact that you keep trying to go after all of them at once is why your issues seem so large. You need the engine to run before you can assess the generator. If it cranks that is a good sign. There is a set of contacts you can jump momentarily inside the regulator and it will make it crank, cycle the key to the start position and back off again to make it stop. I'll get a picture later. Ok you’re right. I was thinking about how would it be a waste of time if starter generator bad while spending all this time on engine .. but given their two different systems.. make sense. Given the tractor has sat for the last year while I’ve worked off and on various issues with it.. would it make any difference to use some marvel mystery oil to help the cylinder since it has sat in same spot for a year? Share this post Link to post Share on other sites
adsm08 5,145 #32 Posted June 19 Marvel is fine, but if you don't have a stuck piston it probably won't do much. Won't hurt either, but won't do much. Did you ever get around to finding out if your issues is fuel or spark? 1 Share this post Link to post Share on other sites
FLtractor 223 #33 Posted June 19 1 hour ago, adsm08 said: Marvel is fine, but if you don't have a stuck piston it probably won't do much. Won't hurt either, but won't do much. Did you ever get around to finding out if your issues is fuel or spark? Not yet.. will have to wait till Sunday.. will update then Share this post Link to post Share on other sites
adsm08 5,145 #34 Posted June 19 (edited) OK, as promised, pictures from inside the regulator. The regulator cover is removed by removing the two screws and lifting it. In this picture the front of the tractor is at the left side of the frame. If you close the set of contacts circled in red, by pressing them closed, or bridging them with a screwdriver, the engine will start to crank, and keep cranking, regardless of key position, if the S/G unit works. The cranking can be stopped by turning the key the whole way to the start/crank position and then turning it back off again. Edited June 19 by adsm08 1 Share this post Link to post Share on other sites
953 nut 69,285 #35 Posted June 19 18 hours ago, FLtractor said: but given their two different systems The drawing below is NOT the wiring system for your tractor but it will show you what the systems are and how they relate to one-another. Share this post Link to post Share on other sites
FLtractor 223 #36 Posted June 21 On 6/19/2026 at 7:13 PM, 953 nut said: The drawing below is NOT the wiring system for your tractor but it will show you what the systems are and how they relate to one-another. Thank you Share this post Link to post Share on other sites
FLtractor 223 #37 Posted June 21 On 6/19/2026 at 8:56 AM, adsm08 said: Marvel is fine, but if you don't have a stuck piston it probably won't do much. Won't hurt either, but won't do much. Did you ever get around to finding out if your issues is fuel or spark? I found out today my issue is definitely fuel.. loosened carb bowl and not even a drop left it in from last week attempt at starting Share this post Link to post Share on other sites
adsm08 5,145 #38 Posted June 21 1 hour ago, FLtractor said: I found out today my issue is definitely fuel.. loosened carb bowl and not even a drop left it in from last week attempt at starting Yes, my experience has been that most combustion engines run better with fuel. My next few steps would be to undo your supply line at the carb, place it in a container and turn the key on long enough to be sure fuel is getting to that point. If it is, blow into the carb's inlet fitting. If you can't blow through it easily then your needle is stuck, or the passage obstructed. Share this post Link to post Share on other sites
FLtractor 223 #39 Posted June 21 2 hours ago, adsm08 said: Yes, my experience has been that most combustion engines run better with fuel. My next few steps would be to undo your supply line at the carb, place it in a container and turn the key on long enough to be sure fuel is getting to that point. If it is, blow into the carb's inlet fitting. If you can't blow through it easily then your needle is stuck, or the passage obstructed. Should I blow into fuel inlet fitting by just blowing and nothing else.. or should I pull off bowl and move float as in this video? Just wanting to learn better- or just blowing and do nothing else- float should raise as in picture, air simulating fuel flow through either hose or just fuel inlet Share this post Link to post Share on other sites
adsm08 5,145 #40 Posted June 21 Just now, FLtractor said: Should I blow into fuel inlet fitting by just blowing and nothing else.. or should I pull off bowl and move float as in this video? Just wanting to learn better- or just blowing and do nothing else- float should raise as in picture, air simulating fuel flow through either hose or just fuel inlet Carb upright, and fully assembled, blow into the inlet. Removing the float or the needle before doing this test invalidates the test for a sticking float or needle. Share this post Link to post Share on other sites
FLtractor 223 #41 Posted June 21 Just now, adsm08 said: Carb upright, and fully assembled, blow into the inlet. Removing the float or the needle before doing this test invalidates the test for a sticking float or needle. Will do just that. Share this post Link to post Share on other sites
clueless 3,439 #42 Posted June 21 What is "fuel leak stop tape" Share this post Link to post Share on other sites
adsm08 5,145 #43 Posted June 21 4 hours ago, clueless said: What is "fuel leak stop tape" I assume he is talking about teflon thread tape. There is a yellow version that is thicker and rated for petroleum exposure. Share this post Link to post Share on other sites
FLtractor 223 #44 Posted June 25 On 6/21/2026 at 2:04 PM, clueless said: What is "fuel leak stop tape" Yes as Adsms said above Share this post Link to post Share on other sites
