adsm08 4,568 #1 Posted 4 hours ago So my Commando 8 has started, in the last day or so here, to give starting issues. After I was done working tonight I checked, charging voltage is between about 11.25- 11.5, static key-off is 11.75. So the battery is a bit rough, but the generator also has an issue. I couldn't find my jumper wires to go full-field, and I didn't have enough hands to do that and hold the voltmeter to the battery anyway. Since a lot of times it won't crank, unless you hit the key over and over, I'm going to go ahead and guess the brushes are worn. I just need some help finding the right ones. Share this post Link to post Share on other sites
953 nut 66,635 #2 Posted 4 hours ago Delco Remy S/G brushes are all over the place on , this looks like a good one. https://www.ebay.com/itm/389153897594?_skw=delco+remy+starter+generator+kit&itmmeta=01KV9D2SJBMZMJ773H60HEFTHA&hash=item5a9b613c7a:g:AUkAAeSwKkRpADO7&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xCzgzZvfAuXMsvM63U8YlX4Qm38dREH%2BEw3hSYobnqmdmQa4Hwmq%2BS7ag96Spv6Z03C5C5HH2fQ451hh5n08M0YljTjsPbrymVZvMtFU5x4RxsOduVQftC0LIag2%2FYxsSylTPGISGYfQEYmi0J3lcSTC1EcdjqDyUFiYYScB7mEcpSO3KpZJl3IFaROZYHJ2t8PWmaNhnMdoSNTJM212Zk90jt0p8vCeoq%2B%2FACQnke6D6v%2F3cwVR5P2S25E%2B5b4DgRnZn9krwwWTQyalXN7FuhxBQaJXKS2swGY7IiazNFQShiAN%2Fy8Fc4fSPaHTchyKKk%3D|tkp%3ABk9SR6iZi63aZw 1 Share this post Link to post Share on other sites
adsm08 4,568 #3 Posted 4 hours ago 5 minutes ago, 953 nut said: Delco Remy S/G brushes are all over the place on , this looks like a good one. https://www.ebay.com/itm/389153897594?_skw=delco+remy+starter+generator+kit&itmmeta=01KV9D2SJBMZMJ773H60HEFTHA&hash=item5a9b613c7a:g:AUkAAeSwKkRpADO7&itmprp=enc%3AAQALAAABAGfYFPkwiKCW4ZNSs2u11xCzgzZvfAuXMsvM63U8YlX4Qm38dREH%2BEw3hSYobnqmdmQa4Hwmq%2BS7ag96Spv6Z03C5C5HH2fQ451hh5n08M0YljTjsPbrymVZvMtFU5x4RxsOduVQftC0LIag2%2FYxsSylTPGISGYfQEYmi0J3lcSTC1EcdjqDyUFiYYScB7mEcpSO3KpZJl3IFaROZYHJ2t8PWmaNhnMdoSNTJM212Zk90jt0p8vCeoq%2B%2FACQnke6D6v%2F3cwVR5P2S25E%2B5b4DgRnZn9krwwWTQyalXN7FuhxBQaJXKS2swGY7IiazNFQShiAN%2Fy8Fc4fSPaHTchyKKk%3D|tkp%3ABk9SR6iZi63aZw Thank you. I'm good at diag, but I'm less good at know I have the right parts. At work I have a parts department for that. Share this post Link to post Share on other sites
wallfish 20,053 #4 Posted 3 hours ago 11 minutes ago, 953 nut said: Delco Remy S/G brushes are all over the place on , this looks like a good one. https://www.ebay.com/itm/389153897594? FYI You can delete everything after the ? when you post a link as that long nonsense stuff afterwards is just tracking. @Handy Don revealed that a while ago and I did not know that before he did. 1 1 Share this post Link to post Share on other sites
