John c 222 #1 Posted June 15 (edited) So I'm running this new C101 I recently found, already ran 45m to an hour, then it just dies, turns out the ground jumper had broken at the engine mount bolt. Get that fixed, and now it won't crank, acts like it out of time, points are set @.020 with the flywheel mark @ "T" and crankshaft keyway pointed straight up, What am I missing ? correction it'll crank, it won't start, pops back through the carb, and fire out of the exhaust Edited June 15 by John c Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #2 Posted June 15 Have another condenser you can try? 1 1 Share this post Link to post Share on other sites
John c 222 #3 Posted June 15 not new I don't, the one that's on it is less than an hour use, but it was an amazon cheapy 1 Share this post Link to post Share on other sites
953 nut 69,242 #4 Posted June 15 Those symptoms could be a faulty condenser. To test this just disconnect the condenser from the ignition coil, the engine can run without it for a short time for testing. If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. 2 1 Share this post Link to post Share on other sites
John c 222 #5 Posted June 15 is the engine shutting down suddenly and under load when the ground cable broke traumatic to the condenser ? I don't have a timing light so I went with .020 with flywheel at "T", that's right isn't it Share this post Link to post Share on other sites
953 nut 69,242 #6 Posted June 15 Your ignition points should just begin to open at the time the "S" appears in the timing hole on the compression stroke, a setting of 0.20 will occur later in the revaluation and there is no particular marking on the flywheel for this. You probably would be best off using the static timing method. The manual covers it well in Section 6, page 9. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,485 #7 Posted June 16 4 hours ago, John c said: not new I don't, the one that's on it is less than an hour use, but it was an amazon cheapy Try the one you took off. 1 Share this post Link to post Share on other sites
rmaynard 17,582 #8 Posted June 16 12 hours ago, John c said: is the engine shutting down suddenly and under load when the ground cable broke traumatic to the condenser ? I don't have a timing light so I went with .020 with flywheel at "T", that's right isn't it No. .020 at the "S" mark Share this post Link to post Share on other sites
John c 222 #9 Posted June 16 Condenser... anybody know of a NAPA part number, or a vehicle application I could use at a local auto parts store to buy a new one Share this post Link to post Share on other sites
953 nut 69,242 #10 Posted June 16 The Kohler 230722 Condenser fits all battery ignition single cylinder and twin cylinder from the K-90 to the K-582. The unit of measure for a condenser is the Farad, and our small engines use a condenser that is in the nanofarad range (ten to the minus ninth power Farads) which is based on the voltage range they work in. A battery ignition system uses a 200 to 500 nF condenser. The lower end of the spectrum is preferable as too high a rating will allow more flow resulting in coil overheating. Do not use a condenser intended for a magneto ignition because its rating is too low and will result in burned ignition point contacts. Most automotive points condensers will be fine. I have used the 1960s Ford condenser ( 250 to 280 nF) because I had a few on the shelf. The 1967 and earlier VW had an ignition coil with a built in resistor like the ones on a Kohler Though they do have a little extra wire on them you can eliminate they too are in the proper range and should be readily available at an auto parts store. 1 Share this post Link to post Share on other sites
John c 222 #11 Posted June 17 Gwest for the win.... I took the cond off my "8" 4speed, double checked the points, and it fired right up. I guess this is what we get now days counting on cheap Chinesium junk from the jungle site, the condenser that failed had maybe an hour of run time. I found a rotary brand that equals #230722S it'll be here in a few days. Fingers crossed this one will hold out a little more than zon brand. thanks everybody Share this post Link to post Share on other sites
John c 222 #12 Posted June 27 So in the end, it wasn't the condenser so much as it was a coil without a resistor, or enough resistance and that was causing the points to burn up. The fact that the ground jumper for the shaker plate broke at the same may or may not have had any bearing on the situation. This was my first time around with a battery powered ignition, I thought a coil was a coil, and was running a new coil as a matter of course. Turns out not enough resistance, point crapped out in about an hour With the help of 953 nut, Gwest and several others I was able to learn about battery powered ignitions and get it back running. thanks everybody 2 1 Share this post Link to post Share on other sites
