Sutty 99 #1 Posted Saturday at 12:17 AM (edited) I am trying to fit my tiller that has not been fitted for 30 years, maybe more. The belt will not go on, no way no how and I think it must have shrunk, or the rubber has lost compliance, so I cannot get it on. It is the only belt I have that's close to this length, so it has to be the right one. My problem is now two fold. My model does not have a lever arm for the spring belt tensioner, and I know when I last used it it did not need the spring. It was so tight, back then, that it was a real pig to get on the big rear pulley anyway, now it seems impossible. Anyway, there is no lever arm on the attach-o-matic pulley and idler that mounts there to apply the spring to. Second, because my model seems to be somewhat unrecognised on here, it's a Belgium machine, I worry that if I get the standard length it will be slightly too long, requiring the spring loaded idler, which I do not have. Is there anywhere to look up what belt length is needed on my specific machine for my tiller? It's a C-140 8 speed, and has serial number 151391. Yes, I know there is no C-140 8 speed in the USA. See below. Everyone seemed very pleased to see one. Also below is the tiller: By the way, it's very late here now, so I won't check back in until tomorrow, so don't think I'm being rude if I don't reply further tonight to any suggestions. Thanks in advance. Regards Sutty Edited Saturday at 12:19 AM by Sutty Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,281 #2 Posted Saturday at 02:00 AM Click on the fuzzy picture Share this post Link to post Share on other sites
Sutty 99 #3 Posted Saturday at 11:44 AM Thank you for the exploded view, and the belt description. I'd read the belt was 139" x 1/2" elsewhere on this site, but was worried it won't be tight enough, without a spring tensioner. However, I have just discovered why I do not have a spring tensioner lever. I think it's fairly clear that it was badly welded, and at some point it has snapped off. The fact that it has paint on the flat metal portion, behind the front weld area, suggests there was no weld there and it was somewhat open. I will have to see what I can come up with. Maybe I can weld something on? Excuse my ignorance, but just in case I get it wrong, can I assume that the 139" will be the inside running length or shall we say, inside circumference? Thanks again. Share this post Link to post Share on other sites
peter lena 9,901 #4 Posted Saturday at 12:01 PM @Sutty glaringly obvious to me ? those , chinese fish oil " lubricated " sealed bearings , are known for failure , and excessissive belt wear , also long unsupported , spring tension enhanced , set up , insures belt bounce . look up some related pictures of the set ups , might find some help , pete Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,281 #5 Posted Saturday at 12:07 PM Belts we use are measured on the outside circumference. Belts shrink with age so a new old belt will measure a bit short. Industrial belts are measured at the internal cord location which allows shaft speeds to be accurately determined. A or 1/2" wide belts add 2" to get the outside circumference. B or 5/8" wide belts add 3" to get the outside circumference. 1 Share this post Link to post Share on other sites
Sutty 99 #6 Posted Saturday at 12:59 PM Thanks Peter, but I'm not sure I follow your post about fish oil. I've looked up a bunch of pictures, and have now clearly identified the issue, the belt tensioner arm has snapped off on my attachment. I have the pulleys off it now, and have a piece of appropriate steel to weld in place. I'm not entirely clear why part number 88 in the picture above has an offset. Many of the photographs I've seen are just flat bar. It doesn't look like I will foul anything with just flat bar, but I need to take a closer look before I can be sure. Can anyone tell me the length of the flat bar for the spring arm? From pictures I could guess, but easier with a measurement from someone, if maybe someone could measure one. Thanks. Thanks gwest for the belt detail. My belt, that I had used before, is 135.625 outside, which explains why it is too short, when it should be 139 outside. It must have shrunk a lot, or was a little shorter to begin with, to make up for not having any tensioner mechanism. Last time I used it, all those years ago, it was super tight. Now it's just a tad beyond that. The following product should be okay then, for when I get my spring arm welded on to my attachment? https://bepltd.com/products/spa3482cr-advance-continental-advance-wrapped-wedge-belt Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,281 #7 Posted Saturday at 01:16 PM I do not know if that belt would work. My metric math says it should work. Datum length 3482mm is 137.08" + 2" for an A (1/2" wide belt = 139" Notice the Datum length is the industrial spec I mentioned. That is measured where the cords that give a belt it's strength are located in the pulley grooves. An industrial pulley may measure 6" OD but will be stamped 5.2. The 5.2 is the diameter where the cords will run. When shaft speeds are designed these are the figures used in applications where pulley diameters determine shaft speeds. Very accurate. If a belt bends backwards over a flat pulley an ideal belt will have the cords located about center of the belt. They can bend both ways placing less stress on the rubber. Most belts have the cords closer to the wide back of the belt allowing it to bend around V-pulleys easier than flat pulleys. The Gates green belts are ideal for both bends and there are others. Share this post Link to post Share on other sites
Sutty 99 #8 Posted Saturday at 02:24 PM It's tricky because mainly I don't know anything about belts. I do know that many sites have A136 or A138, but no A137, which is the 139" outer that's needed. If I do find an A137, it often looks worryingly poor quality, like some no name eBay item. The one I linked, like all I've seen, has the cords near the flat side. It is the classic profile shown below. Share this post Link to post Share on other sites
Sutty 99 #9 Posted Saturday at 03:16 PM I can't find those Gates green A137 over here. I think I'll just have to try the one I linked. Do you happen to know the length of the tensioning arm, from where it is shown broken off in my picture? Share this post Link to post Share on other sites
Razorback 1,353 #10 Posted Saturday at 03:35 PM (edited) 27 minutes ago, Sutty said: I can't find those Gates green A137 over here. I think I'll just have to try the one I linked. Do you happen to know the length of the tensioning arm, from where it is shown broken off in my picture? I hope these pics help. The top of that measuring tape is inches, bottom is centimeters. Mine uses an A139 belt. Edited Saturday at 03:44 PM by Razorback added soem text Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,281 #11 Posted Saturday at 03:38 PM You can see in your illustrations how a reverse bend would severely stress the rubber on the inside of the belt. The green belts do not come in the A & B sizes and do not see a direct replacement for 1599. Some applications called for a 141" belt which may work for you since the spring tensioner appears to have a lot of travel. Sorry have never had one so do not know dimensions of the idler. See Toro still has the 141" 110265 but expensive. Share this post Link to post Share on other sites
Sutty 99 #12 Posted Saturday at 04:21 PM Thanks for the pictures Razorback, I will cut it to the length you show there and drill accordingly. Yes gwest, thanks, I can see how that would stress it more, it would be stretched a lot on the outside curve. Having said that, I'm doing a couple of small areas, and it will be worth it for £40, if it lasts out the job. My welding skills are appalling, but I think in this case they will be good enough. The other side is the same quality, or lack thereof. Share this post Link to post Share on other sites
Razorback 1,353 #13 Posted Saturday at 04:52 PM (edited) @Sutty I’m not sure if it matters much, but in my second picture, can you tell that there is a compound bend in that flat stock? Where the vise-grip is clamped is in the middle of the two bends. I think the top end where the spring attaches ends up in line with the outside of the pulley. I’ll get another pic …. Edited Saturday at 05:05 PM by Razorback Share this post Link to post Share on other sites
Sutty 99 #14 Posted Saturday at 05:28 PM Yes, thanks, I mentioned it up the thread. Part 88 in the drawing, clearly shows it, but many photos of other people's didn't seem to have it. I checked mine, and it shouldn't interfere with anything, so I've left it flat like many of the photos of other people's. If it does need it, it won't be difficult to add it, and will lose hardly anything off the length. I've finished it now, and painted it with red oxide primer, which I'll have to run it with until I can get hold of some Wheel Horse red. Good enough, I think. Just need the belt now. 1 Share this post Link to post Share on other sites
Sutty 99 #15 Posted Saturday at 06:37 PM SPA is the wrong profile, according to Claude AI, but it found me one over here that was correct, so the belt is on order now. Should get to see if it all works in a few days, when it arrives. With trial fits of the short belt, I worry that there is part of the bodywork that appears to foul the edge of the belt, near the back. It appears as if someone has already nibbled it away to give clearance, or it is notched to begin with, but it's close, for sure. I'll have to take the right rear wheel off to have a much better look. Fishing all day tomorrow, so it will have to wait a while. 1 Share this post Link to post Share on other sites
Razorback 1,353 #16 Posted Saturday at 09:46 PM While outside today I looked at the drive belt on my tiller. It doesn’t have any markings on it but I compared it to a B142 I have hanging in the shed. The tiller belt sure looks like a B profile on mine. It’s working just fine, but if I ever replace it, I will get an A139. This belt is what came with the tiller when I got it in 2018. Share this post Link to post Share on other sites
Sutty 99 #17 Posted Sunday at 12:52 AM (edited) My late father got the wheel horse from our next door neighbour back in 1978-ish, I imagine it was a few years old, 2 or 3. So we are the two owners, next door neighbour, and my dad and me, if you class us as one. Same family at least, lol. I know when I used the tiller last, like I said, thirty years ago or more, it worked fine without the spring loaded idler, with just the tight belt. I don't even know what the difference is between an A profile and a B profile, so from my perspective, I had no real choice than to go with what is recommended in here. That belt would almost certainly have come with it from our neighbour back then, in 1978, so I suspect it is original. Maybe not, but for sure it is at least thirty years old. I just looked up what the difference is, and discovered it's just size from what I read. If that's right, 17 mm x 11 mm instead of 13 mm x 8 mm, the pulleys look like they might be a tight fit for the 17 mm back, but if you say it works, it works. Edited Sunday at 12:53 AM by Sutty Share this post Link to post Share on other sites
Sutty 99 #18 Posted 4 hours ago I was right about the rubbing, so I took the wheel off to have a better look. Any idea why it would rub on the plate covering the main belt drive to the gearbox? If I push that in, as you can see in the video, I can make it clear it, but then if I were to wedge it into that position the opposite face rubs on the pulley behind. My thought is to fold over that return edge, effectively bending it flat. It also rubs on one of the axle clamp bolt heads. They are smooth dome heads, to is should be fine, but it's confusing. Any thoughts? This second video just shows the path, and how tight it is, even though this is my new 139" belt. There's zero point in the spring, it would add nothing to such existing tension, plus the tensioning arm that I welded on is way out of the way, and my spring will never reach. It the belt were longer, the arm more vertical, and the spring more possible and useful, it may well clear the dome head bolt at the rear, I suppose. I think I'll go with just crimping over that return edge that fouls, and see what happens. You can see some sort of notch that someone has taken out of it there, so the previous owner must have spotted it too. Cheers Sutty Share this post Link to post Share on other sites
Sutty 99 #19 Posted 4 hours ago Ah, could my axle clamps be off centre? I'll go look if that's a possibility. Those have never ever been removed. I assume they can be? Share this post Link to post Share on other sites
Sutty 99 #20 Posted 2 hours ago (edited) Yep, that was it. Annoying, because the whole thing had to come off again, but I'm getting good at that now, lol. Very pleasing not to have to worry about chafing the new belt though now. No idea which numb nuts fitted it so far off centre, but it wasn't me. Doubt they had slipped across either, because they were very tight. Dome nut head doesn't foul when lower even a tiny bit, so that won't be a problem either. I bet a 141" belt could have my spring tension in the right place too, but maybe my new belt will ease, given time, not sure. I won't be buying a longer belt to find out, because I just want this one job doing, and then it will be back in the shed, and right now the tension is pinging tight, without spring. That did surprise me, considering how much extra length the new belt should have over what I measured the old one to be. Oh well, I'll crack on with it, and give it a run. Was just having a break and a cup of tea, so thought I'd post an update. Edited 2 hours ago by Sutty 1 Share this post Link to post Share on other sites
Sutty 99 #21 Posted 1 hour ago (edited) Achieved part one of what I wanted to get done. Part two is a similar sized area elsewhere. Very satisfied. Just wanted to till it a few inches down, ready to try some shade tolerant grass. Bit of an experiment, because it's well shaded, and pretty dark, but the according the website, they say it practically grows in the dark. We shall see. Need to pick out some roots, and rake it, but otherwise it's good enough. Too tired to do that today though. I'm not fit enough at my age to have done that, without the wheel horse, because it had such a solid crust, from having had no grass for so many years. Great machine. Edited 1 hour ago by Sutty Share this post Link to post Share on other sites
