Retired Wrencher 6,993 #1 Posted June 11 i’m giving this JB weld a try. It is muffler cement It had a big crack at the base about half way around. I have some big wire wheels and I brush the heck out of it clean it up the best I could and then I applied the muffler cement. Let’s sit overnight and this is the way it turned out once I got the engine running I guess time will tell if it’s gonna last right now. It seems to be pretty stable. Hope you enjoy the video and the pictures. IMG_1245.mov 1 Share this post Link to post Share on other sites
ri702bill 13,162 #2 Posted June 11 (edited) If you reincorce it with some 2x2 aluminum screen patch(es), it limits movement & works well. I did just that to repair an annoying porosity in my C81 K181 block behind the starter. (it was at the casting parting line). That was 6 or so years ago, still no leak. Edited June 14 by ri702bill 1 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #3 Posted June 11 47 minutes ago, ri702bill said: If you reincorce it with some 2x2 aluminum screen patch(es), it limits movement & works well. I did just that to repair an annowing porosity in my C81 K181 block behind the starter. (it was at the casting parting line). That was 6 or so years ago, still no leak. Bill I did start it up it does not move shake or wobble from front to back any more. But time will tell how if it holds up. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,484 #4 Posted June 13 If it does hold up I would paint that entire muffler with hi-heat black 1 Share this post Link to post Share on other sites
Retired Wrencher 6,993 #5 Posted June 14 On 6/12/2026 at 8:04 PM, Sparky said: If it does hold up I would paint that entire muffler with hi-heat black That is the plan Mike. Fingers crossed. It is pretty much for plowing snow not sure how much use it will get for the summer.Time will tell? 1 1 Share this post Link to post Share on other sites
RED-Z06 2,720 #6 Posted June 17 My big Simplicity has a narrow area of rot in thr top of the muffler canister, its not structural but i wire wheeled it, soaked in 30% vinegar, wire wheeled, ive tried 6 different products including this one. The problem has been the pressure eventually (usually a half hour), pushing the stuff off. I finally relented and welded a plate over it. Share this post Link to post Share on other sites
Retired Wrencher 6,993 #7 Posted June 17 2 hours ago, RED-Z06 said: My big Simplicity has a narrow area of rot in thr top of the muffler canister, its not structural but i wire wheeled it, soaked in 30% vinegar, wire wheeled, ive tried 6 different products including this one. The problem has been the pressure eventually (usually a half hour), pushing the stuff off. I finally relented and welded a plate over it. RED-Z I used just about the hole tube on it. So far so good. I will keep an eye on it through the year. And see if it holds up or not. Share this post Link to post Share on other sites
