Strokerace2639
Surging/Hunting
Strokerace2639
 Yes I understand there are many threads about this. As they as a few years old, and I just picked up this machine I am starting a new.
  1988 Wheel Horse 520-H bought from original owner.
  only parts I have replaced to this point are the Fuel Filter and the starter solenoid.
 Runs great on start up and until its good and warm ( 15 minutes or so), then  it starts surging/hunting. The engine speed goes up and down, the vacuum goes from like 2 to 15 very rapidly, under load. As
soon as I stop the mower deck it settles right back to what I would consider normal.
  Sets already  done.   used propane and starter fluid around the intake and carb. found no noticeable changes.
i did notice the fuel filter never seems FULL. is this normal?
What are the things I should look at and in what order?
Thank You, StrokerA
sqrlgtr
Posted (edited)
just acquired a 520H a few months ago same symptoms and the 2 piece manifold was leaking/sucking air. Replaced manifold and runs like a champ now. I did clean/rebuild carb while I had it apart also dun  a good cleaning of engine cooling fins whist I was in tare down mode...Oh yeah had a bad oil leak at oil drain where it goes into block. Just some well needed love and ready for another 30 years :DF0462DE4-CF92-44B8-8463-0862D32DF0C5.jpeg.d85e3570e7a669ac65f8eef98f203dae.jpeg45923264-9A02-4BED-BC8F-99BF147C86BC.jpeg.8e8ad5ddd4c3aae1158f0ef87c2cdf7d.jpegE39C9E65-41EA-405F-9BB9-C301F5D95DA4.jpeg.722328550aad343a7a03b46ab5204c42.jpegD45A0EEB-8548-4BC9-A275-4FB7F8687477.jpeg.a8d3346df746ffba0c595f8d60d02658.jpeg
A few pictures for encouragement/courage :D
Edited by sqrlgtr
sqrlgtr
Almost forgot Welcome to :wh:
Ed Kennell
Posted (edited)
1. clean the carb
2. clean the carb
3. clean the carb
                     :text-welcomeconfetti:to the :rs:
Edited by Ed Kennell
  • Excellent 2
953 nut
:WRS:
:confusion-confused:                Perhaps a vacuum hose has a small crack which is aggravated by the vibration of the mower deck.
Strokerace2639
2 hours ago, Ed Kennell said:
1. clean the carb
2. clean the carb
3. clean the carb
 Yeah thats what  I was thinking..  best way to do that? can I get away with just removing the 4 screw from the top of the carb? then use something like permatex orange on reassembly? I normally remove gaskets and use stuff like Sillycone or TheRightStuff. Never had anything leak yet.
Thank You!
Strokerace2639
2 hours ago, 953 nut said:
:WRS:
Thank you and your Family for your Service.
Bill D
Thank You!
Take the top off the carb.   Clean the bowl and main jet with cleaner and compressed air.  Be careful not to lose any small parts, or drop them down the intake.   Do not use sealant on the gasket when reassembling.   You may have to clean it several times.
kpinnc
I would also run a fine bead of silicone or similar on the seam of the two piece intake manifold. All the way down the seam on both sides.
That, along with cleaning the carb worked wonders for my 520-H.
parsonsponyz
:text-welcomeconfetti:to Red Square.
Pull the carb off and do a thorough cleaning.
lynnmor
It is best to pull the intake in order to remove the carburetor for proper cleaning.  It makes sense to do a valve adjustment at the same time since the intake needs removed to do that.  Before doing any of that, check the compression to see if there may be other problems.  Use only genuine Onan gaskets for the intake, valve covers and exhaust and torque to specs found in the Onan Service Manual that can be downloaded in the Manuals section.  The cheap kits found on the auction site are rather poor quality but some of the parts are OK, I use the carburetor bowl gaskets without issue but the manifold gaskets and needle are junk.  Use no goop on the carburetor, check the intake manifold for leaks while off by blocking the carb port and filling it with gas, kerosene or diesel fuel, if a leak is found come back for guidance on that repair.  Follow the manual and do nothing that you aren't sure of, return here for advice.
  • Excellent 2
Strokerace2639
I think the following are the correct but feel free to correct me if I am mistaken, ( these are from ONANPARTS.com
  intake manifold gaskets- 154-2495
  carb gasket                   - 146-0657
  valve cover gasket        - unknown to me
Thank You.
lynnmor
Thank You.
If the listings say the parts are for an Onan P220G, they would be correct.  Download the Onan Service Manual to see what you need, all of the 20 HP Onans are about the same, one exception is the valve cover gaskets where the breather design changed and the old style with the breather in a valve cover took 3 gaskets instead of 2.  Onanparts sells good parts but he appears to be having difficulty getting some parts, lay in spares that you might need in the future.
Strokerace2639
update:   While I wait for parts to arrive. as suggested by another forum member I,
                choose to do a compression test. I got the following.   Front       Back
        Dry       110         120
        Wet       120         120
            I am also adding a pic of the plugs.
           As the problem is far worse with mower deck engaged I think I am also going to add new
           vacuum hoses just to be safe...
              Keep wishing me  luck.
 Thank You.
oliver2-44
The plug on the left has a nice tank color which they say is good.
The plug on the right is white which I think means it is operating on the lean side.
dirty carb, carb adjustment or air lean could make it lean.
Better to have  it rich than a little lean.
Strokerace2639
AGREED!
Strokerace2639
update: update:    so to this point I have only done the fuel filter and seafoam in the gas..
                              Day 1-  surging on start up.
                              Day 2- Surging after about 7 minutes of use
                              Day 3- Surging after about 10 min of use
                              Day 4- (really a few days later) got a good 15 min out of it before the surging
                              Day ??-      about the same as last time
                              Day TODAY-   2 runs at over 30 minutes and 1 little hick-up other than this it seems good.....
now to decide if I work on my 312-H or let it go to someone else that wants to work on it...
THANK YOU EVERYONE.
