WHwest8597 85 #1 Posted June 5 I have a 314-H Model: 73401 Serial: 5901202 I just replaced the drive belt with a toro oem belt. I noticed the cold start lever is vibrating quite a bit. Any suggestions on why this is happening? Share this post Link to post Share on other sites
ineedanother 2,885 #2 Posted June 5 44 minutes ago, WHwest8597 said: I noticed the cold start lever is vibrating quite a bit. Any suggestions on why this is happening? Two #2 phillips through the dash plate with nuts on the back side. Probably just need to be tightened. 1 Share this post Link to post Share on other sites
JoeM 10,318 #3 Posted June 6 old belt must have been smoother?? might need to replace idler pulley with a new one? i’ve seen it to and makes you wonder how true are the new belts Share this post Link to post Share on other sites
ineedanother 2,885 #4 Posted June 6 I guess I didn't have my brain engaged. @JoeM is on it. Those parts wear and rattle more than anything else on my hydros. That's one area I wish was easier to access. A good bit of disassembly to maintain properly. Share this post Link to post Share on other sites
