wfopete
School me on the D160
wfopete
Looking at a D160. I plan to see it up close,  pictures show it to be in very nice condition.  I'm concerned about if later model decks and other attachments will work with these units.  Also what areas should I be checking close with this model?
pfrederi
D 160-200 attachments are unique to that series.  Decks, Blowers and plows from C 300/400 series will not fit There are two versions of D160 some came with Kohler K341  other with a twin onan.
  • Excellent 4
wfopete
That's good to know.  Parts availability is important for the long term; are parts like finding hen's teeth?  Are there any reliability issues with these. Ideally I was looking at the 300 series but this D160 popped up on FB claiming it was restored.  Priced at $1800 so I don't want to go into this without some knowledge on the model.
pfrederi
Restoration  can mean a lot of things ranging from a quick wash and a bit of paint to overhauled engine and hydro.  Personally I would much prefer the Kohler, parts for that are plentiful Onans not nearly as much.  Onan has an electric PTO not sure about parts for that.
  Big thing is to test the hydro.  Get it warmed up there may be a hydro temp gauge  to check that.  Then put it up against an immovable object and see if it will dig holes with rear tires.
What are you planning on using it for.  They are big heavy not the most maneuverable tractor  overkill for lawn mowing....
wfopete
Id rather stay away from the Onan too.   I'm not a hydro fan either but if unit is solid I could live with it.  I have not seen a D series up close so I can't appreciate what it is or isn't. What years was the D series produced?
Edited by wfopete
pfrederi
First year it was only an 18 hp and called 18.  1973 last year was 1981.  Not much changed over the years.  Some modifications to the motion control and parking brake setup.  The are heavy over 1000 lbs.  I would ask again what you are planning on doing with it.  I have a D200 but it has an FEL.  If you want to add a rotor tiller or 5' finish mower you have to add a rear PTO unit and 3 pt hitch.
D160 did not come standard with 3pt hitch or rear PTO they were an option.
Edited by pfrederi
pfrederi
I notice you have a Lawn Ranger...The front wheels and tires on most D series are the same size as your lawn rangers back tires....
  • Haha 1
wfopete
LOL! Yeah, for sure they are a beast and more than I need just for mowing. Ugly as sin too (IMO).
ri702bill
Also be aware that the D Series tractors were made in Belgium & imported here by / for WH. My FIL had a D250 that came with a 25HP Renault 4 cylinder liquid cooled car engine and car style clutch. A beast of a tractor.
pfrederi
 Only the D250s were made in Europe. D160-200 all made in US
