FLtractor 161 #1 Posted 19 hours ago Evening, wondering how many gallons a stock 856 fuel tank holds. Share this post Link to post Share on other sites
squonk 46,633 #2 Posted 19 hours ago I think around 2 quarts Share this post Link to post Share on other sites
FLtractor 161 #3 Posted 16 hours ago 2 hours ago, squonk said: I think around 2 quarts Thank you. Have a conundrum… gonna be running hopefully driving my 856 tomorrow after a year of various work on it and delay.. has new fuel line.. aftermarket Amazon carb.. never filled or run with fuel yet.. new fuel filter.. fuel clamps.. brand new never run electronic fuel pump.. I have 2 and 5 gallon plastic gas cans of gas cans non ethanol fuel without stabol.. stored under a lean too.. central Florida. Fuel bought specifically for tractor but now is probably a year old now.. should I use it in tractor or empty and fill with new non ethanol fuel and put in stabil in cans this time for unused fuel Share this post Link to post Share on other sites
adsm08 4,500 #4 Posted 16 hours ago (edited) Yes, that tank holds 1/2 a gallon. I'd put about a quart in the tractor and see how it runs on that stuff. If it runs poorly don't waste the old fuel, just put it in a car, the car will run fine even on stale fuel, then get fresh for the tractor. If you only have half a tank, or a little less, of stale fuel that leaves plenty of room to dilute it with fresh. I try not to store fuel more than a few weeks, but it should be good for at least six months. Edited 16 hours ago by adsm08 2 Share this post Link to post Share on other sites
FLtractor 161 #5 Posted 16 hours ago 9 minutes ago, adsm08 said: Yes, that tank holds 1/2 a gallon. I'd put about a quart in the tractor and see how it runs on that stuff. If it runs poorly don't waste the old fuel, just put it in a car, the car will run fine even on stale fuel, then get fresh for the tractor. If you only have half a tank, or a little less, of stale fuel that leaves plenty of room to dilute it with fresh. I try not to store fuel more than a few weeks, but it should be good for at least six months. Oh ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? Share this post Link to post Share on other sites
kpinnc 18,293 #6 Posted 16 hours ago 15 minutes ago, FLtractor said: ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? Not that I have ever seen. 1 Share this post Link to post Share on other sites
adsm08 4,500 #7 Posted 16 hours ago 15 minutes ago, FLtractor said: does adding stabol to the non ethanol fuel affect it negatively at all? No Share this post Link to post Share on other sites
Retired Wrencher 6,687 #8 Posted 7 hours ago 12 hours ago, FLtractor said: Evening, wondering how many gallons a stock 856 fuel tank holds. FLtractor. The only you need to know is you can ride for hours on one tank. These little K181 are great gas mileage with these engines.. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,687 #9 Posted 7 hours ago 8 hours ago, FLtractor said: Oh ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? I use it all the time regardless if it’s ethanol or non ethanol. What I use you can put two cap fulls that will treat 2.5 gallons. So pretty cheap to use. Share this post Link to post Share on other sites
squonk 46,633 #10 Posted 5 hours ago When I plowed snow with my 1267 it emptied that tank in about an hour. Share this post Link to post Share on other sites
