FLtractor 187 #1 Posted May 31 Evening, wondering how many gallons a stock 856 fuel tank holds. Share this post Link to post Share on other sites
squonk 47,358 #2 Posted May 31 I think around 2 quarts Share this post Link to post Share on other sites
FLtractor 187 #3 Posted June 1 2 hours ago, squonk said: I think around 2 quarts Thank you. Have a conundrum… gonna be running hopefully driving my 856 tomorrow after a year of various work on it and delay.. has new fuel line.. aftermarket Amazon carb.. never filled or run with fuel yet.. new fuel filter.. fuel clamps.. brand new never run electronic fuel pump.. I have 2 and 5 gallon plastic gas cans of gas cans non ethanol fuel without stabol.. stored under a lean too.. central Florida. Fuel bought specifically for tractor but now is probably a year old now.. should I use it in tractor or empty and fill with new non ethanol fuel and put in stabil in cans this time for unused fuel Share this post Link to post Share on other sites
adsm08 4,778 #4 Posted June 1 (edited) Yes, that tank holds 1/2 a gallon. I'd put about a quart in the tractor and see how it runs on that stuff. If it runs poorly don't waste the old fuel, just put it in a car, the car will run fine even on stale fuel, then get fresh for the tractor. If you only have half a tank, or a little less, of stale fuel that leaves plenty of room to dilute it with fresh. I try not to store fuel more than a few weeks, but it should be good for at least six months. Edited June 1 by adsm08 2 Share this post Link to post Share on other sites
FLtractor 187 #5 Posted June 1 9 minutes ago, adsm08 said: Yes, that tank holds 1/2 a gallon. I'd put about a quart in the tractor and see how it runs on that stuff. If it runs poorly don't waste the old fuel, just put it in a car, the car will run fine even on stale fuel, then get fresh for the tractor. If you only have half a tank, or a little less, of stale fuel that leaves plenty of room to dilute it with fresh. I try not to store fuel more than a few weeks, but it should be good for at least six months. Oh ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? Share this post Link to post Share on other sites
kpinnc 18,736 #6 Posted June 1 15 minutes ago, FLtractor said: ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? Not that I have ever seen. 2 Share this post Link to post Share on other sites
adsm08 4,778 #7 Posted June 1 15 minutes ago, FLtractor said: does adding stabol to the non ethanol fuel affect it negatively at all? No 1 Share this post Link to post Share on other sites
Retired Wrencher 6,783 #8 Posted June 1 12 hours ago, FLtractor said: Evening, wondering how many gallons a stock 856 fuel tank holds. FLtractor. The only you need to know is you can ride for hours on one tank. These little K181 are great gas mileage with these engines.. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,783 #9 Posted June 1 8 hours ago, FLtractor said: Oh ok will do that thank you. does adding stabol to the non ethanol fuel affect it negatively at all? I use it all the time regardless if it’s ethanol or non ethanol. What I use you can put two cap fulls that will treat 2.5 gallons. So pretty cheap to use. Share this post Link to post Share on other sites
squonk 47,358 #10 Posted June 1 When I plowed snow with my 1267 it emptied that tank in about an hour. Share this post Link to post Share on other sites
FLtractor 187 #11 Posted June 1 7 hours ago, Retired Wrencher said: FLtractor. The only you need to know is you can ride for hours on one tank. These little K181 are great gas mileage with these engines.. That’s great to know.. when I originally emptied all the old fuel out from the 1/2 to 3/4 tank from previous owner .. I was surprised at just how long it took to empty it from the fuel valve beneath the tank. Share this post Link to post Share on other sites
FLtractor 187 #12 Posted June 1 7 hours ago, Retired Wrencher said: I use it all the time regardless if it’s ethanol or non ethanol. What I use you can put two cap fulls that will treat 2.5 gallons. So pretty cheap to use. Thank you for the cap idea Share this post Link to post Share on other sites
FLtractor 187 #13 Posted June 1 6 hours ago, squonk said: When I plowed snow with my 1267 it emptied that tank in about an hour. No snow hear from my guess is mowing short grass and or towing a yard cart would be less stress than heavy wet snow so probably better time than that in my case. Thank you for the comparison. Share this post Link to post Share on other sites
FLtractor 187 #14 Posted June 1 Thank you all for the advice and support Share this post Link to post Share on other sites
