MidMoTractorMan 3 #1 Posted May 31 I have a wheel horse 520 H my problem is something to do with the fuel I have put new fuel lines on new fuel pump and it seems like it's not picking up fuel because I've got a clear fuel filter On it it will stay half full then it seems like once it gets warm I lose fuel in my fuel filter I don't know if it's getting too hot and evaporating but I had bowed all the cooling fins and stuff out I just took the float out thinking that the float may be stuck but I am out of ideas need help Share this post Link to post Share on other sites
Ed Kennell 46,981 #2 Posted May 31 Fuel tank cap vent may be clogged. Try running it with the fuel cap loose. Screen in the tank may be clogged. Pull the line off at the tank to check for free flowing fuel. to the 2 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #3 Posted May 31 Are all the fuel hoses new. New hose is soft and will seal on the nipples. Hard hose will likely leak and allow the fuel pump to suck in air at the nipples. And the same will will not allow fuel to leak when not under vacuum so makes it hard to diagnose. The fuel pump will suck air if it gets a chance because it is easier to pump air than fuel. Air can be compressed and expanded so a short vacuum pulse from the pump just plays with the air. The pulse does not have enough duration to pull a bit of fuel with it. That is why electric pumps located near the tank are a good choice. Most of the fuel line is under pressure. It is normal to see a fuel filter half full but they should never go empty. At half full the inside of the cartridge will have fuel in it at the filter outlet but you can not see that. 1 Share this post Link to post Share on other sites
MidMoTractorMan 3 #4 Posted May 31 All right everything that you guys have mentioned I've already tried my fuel cap is cracked so I know it is getting vented I don't think there is a screen because when I first got the mower the rubber grommet was dry rotted and was leaking fuel I pulled it out in one piece and put a new petcock in it so I don't think that's the problem all my hose clamps are tight on the fuel lines what electric fuel pump would you guys recommend 1 Share this post Link to post Share on other sites
squonk 47,887 #5 Posted May 31 Need a picture of your filter and how you got it mounted. I have seen 1 style of clear filters that like to get air locked Share this post Link to post Share on other sites
Ed Kennell 46,981 #6 Posted May 31 (edited) OK, check the fuel supply to the carb. Pull the line off at the carb. and crank the engine while you hold the line in a container. You should see a strong spurting supply. If not install an electric pump as low as possible near the tank. Do not let the pump run dry. You need a 2-3.5 PSI pump. I have had good results with Carbole. They come with a inlet filter to protect the pump. Amazon.com: CarBole Gasoline Electric Fuel Pump Universal 5/16 Inch Inlet and Outlet Inline 12V 1-2A 28GPH 2-3.5P.S.I. Operating Fuel Pressure : Automotive Edited May 31 by Ed Kennell 3 Share this post Link to post Share on other sites
peter lena 10,013 #7 Posted May 31 @MidMoTractorMan regular for me ? always run in a recovery on a seperate gallon of heavily treated fresh fuel ? eliminate , probable , dirty tank and fuel hose break down , thats another step , you will find as you go, every stage has multiple probable issue's , learn / correct / change , eliminate , nothing sarcastic , but personally love repetitive problems ? usually just a functional detailing . lots of areas , make sur your tank cap is venting for flow , pete Share this post Link to post Share on other sites
ol550 870 #8 Posted May 31 Does the engine bog down or die when this happens? Share this post Link to post Share on other sites
lynnmor 9,010 #9 Posted May 31 A large air pocket in the fuel filter is perfectly normal. If you have a problem with how the tractor is operating, state what that is. 1 Share this post Link to post Share on other sites
MidMoTractorMan 3 #10 Posted June 1 I think I found the problem it was my plastic shut off valve I took it off and I mowed all day today with it but if I still have problems I will put electric fuel pump on it thanks guys for the info 1 1 Share this post Link to post Share on other sites
peter lena 10,013 #11 Posted June 1 @MidMoTractorMan not just any electric pump ! strongly suggest the carbole micro electric , LOW PRESSURE 2-3.5 PSI , very solid reliable , have mine just in front of engine , fuel filter at tank as well as just before carb , years in usage , no problems , pete 1 Share this post Link to post Share on other sites
