oldlineman 1,821 #1 Posted May 30 Just a quick question, do you have to remove the oil fill dipstick tube in order to remove the starter? 1989 c-414, kohler M 12. Thank you Share this post Link to post Share on other sites
953 nut 70,649 #2 Posted May 30 Yes, though someone on here has probably managed to do so without removing it. Now that I have given a definitive answer somebody has to controdict it. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #3 Posted May 30 Took a while to find it. #12 & #13 1 Share this post Link to post Share on other sites
Bill D 3,213 #4 Posted May 30 Worst starter design ever. K series is much better. 1 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted May 30 22 minutes ago, Bill D said: Worst starter design ever. Cadillac Northstar says "Hold my beer!" 3 Share this post Link to post Share on other sites
Bill D 3,213 #6 Posted May 30 57 minutes ago, squonk said: Cadillac Northstar says "Hold my beer!" I stand corrected! 1 Share this post Link to post Share on other sites
Ed Kennell 47,942 #7 Posted May 30 6 hours ago, oldlineman said: Just a quick question, do you have to remove the oil fill dipstick tube in order to remove the starter? 1989 c-414, kohler M 12. Thank you Yes, and due to the tight clearance to the starter 12v. lug, I install a rubber sleeve on the fill tube to provide insulation. 1 2 Share this post Link to post Share on other sites
adsm08 5,247 #8 Posted May 30 1 hour ago, squonk said: Cadillac Northstar says "Hold my beer!" The 5-cylinder in the Colorado was even worse. Same stupid spot, much harder to remove the intake. 1 Share this post Link to post Share on other sites
oldlineman 1,821 #9 Posted May 31 Thank you everyone, I sort of figured that it had to come off, now for the next question will oil come out if you take said fill tube off without draining engine oil? Thanks Share this post Link to post Share on other sites
Achto 32,962 #10 Posted May 31 7 minutes ago, oldlineman said: now for the next question will oil come out if you take said fill tube off without draining engine oil? The oil level should be below the dip stick housing. Should be able to remove it with out leaking oil. 1 1 Share this post Link to post Share on other sites
