John c 157 #1 Posted 21 hours ago (edited) I've got what I think may be a rectifier given up 1978 C101 8spd. K241 engine battery not charging when running, 12.65vdc when off 12.50vdc when running 12.35vdc running, headlights on Battery is new in good condition, As close to a manual as I have is one for magnum series Kohlers, based on that I read the following: Neither of the stator leads show shorted or grounded, about 2~3 ohms between them, and 34ish-vac output at full throttle. So I suspect the rectifier is at fault is there a chart showing points to test and values to expect to troubleshoot the rectifier ? I've got others laying around, so how interchangeable are they among other sizes engines Also how can you determine what amperage the stator is rated for ? Thanks, john Edited 21 hours ago by John c Share this post Link to post Share on other sites
ri702bill 12,138 #2 Posted 19 hours ago The rectifier housing must be grounded. Over time, oxidation builds up on the two mounting fasteners. Try jumping the housing to ground (not the fasteners) and retest. If it works, unmount it & clean the mounting area. Some of us add a ground wire between the rectifier housing and the screw head.... A freshly painted surface can cause issues too if the rectifier is attached to it... 2 1 Share this post Link to post Share on other sites
John c 157 #3 Posted 17 hours ago OK, I'll try that tomorrow, this old machine has plenty of rust all over it, so this may be something. So is there a way to tell the rating of the alternator ...that doesn't involve taking the flywheel off the engine ? Share this post Link to post Share on other sites
Achto 31,826 #4 Posted 16 hours ago 27 minutes ago, John c said: So is there a way to tell the rating of the alternator ...that doesn't involve taking the flywheel off the engine ? The spec number on the engine should help get you this information. 2 Share this post Link to post Share on other sites
John c 157 #5 Posted 6 hours ago the spec number on the engine is 46766d, anybody have a chart explaining what the number means ? Share this post Link to post Share on other sites
953 nut 66,196 #6 Posted 5 hours ago The Spec. Number is located on the engine data plate, once you have that number you can be sure what parts are correct. Unless you are absolutely sure the engine is the one kit left the factory with you can't be sure just by using the year of the Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,242 #7 Posted 5 hours ago That specification number is assigned to identify how the engine was configured for the intended Kohler customer. The K241 engines have their own series of spec numbers. When you go to the parts list you will see in this case there are two different stators illustrated in it but only one is listed in the list - the one that the spec number specified. https://www.partstree.com/models/k241-46766-kohler-k-series-engine-made-for-wheel-horse-10hp-7-5kw/breaker-ignition-3/ Another way to identify the stator is to look at the location of the regulator terminals and their relationship to each other. The 10 amp and 15 amp are different. Here is where the original illustrated parts lists started. Take your spec number with you Share this post Link to post Share on other sites
953 nut 66,196 #8 Posted 5 hours ago (edited) Your engine Spec Number shows it being a 1979 K-241 which is correct for the '79 C-101. Going into the K-241 parts manual Groupe 18 (charging and ignition) we find the number 114 applies to all components related to charging for that engine. You have a 15 amp charging system and the parts illustrated below are correct for your engine. We know that your stator is working properly based on the test you have done. Your voltage regulator / rectifier should be a 15 Amp unit. It has three tabs in an "L" pattern. I have attached a link to the parts manual for you. Edited 5 hours ago by 953 nut add photo 2 Share this post Link to post Share on other sites
John c 157 #10 Posted 2 hours ago (edited) Mine has the "L" shape connector plug, indicating a 15A charging system then I guess. So I started with simply adding a battery ground connection to the case of the rectifier with so change seen in voltage, so then I took it off completely cleaned all the electrical connections with fine sandpaper, contact cleaner and compressed air, also took the 3 wire connector plug apart and did the same thing. I added a wire from battery ground to under the bolted connection that holds the rectifier to the frame. Once back together I was seeing 13.65vdc with the engine running, but not a steady state 13.65, it slowly fell back to about 12.40, Once there it would maintain that level when adding load to it (headlights) The fact it holds voltage under load makes me think it's working, but then why won't it hold 13.5 +, and then the 12.4vdc looks to me like the ignition is running on the battery alone. Does my new ground sound sufficient and I do in fact have a defective rectifier ? Or should I add a tapped screw to one of the cooling fins on the rectifier to make grounded connection Any of you guys been down this path before ? Edited 2 hours ago by John c Share this post Link to post Share on other sites
pfrederi 20,582 #11 Posted 2 hours ago Sounds like time for a new rectifier.... 2 Share this post Link to post Share on other sites
John c 157 #12 Posted 1 hour ago that's what I'm thinking too, How much interchangeability is there among these things, I've got several on hand, I suppose they're rated in amps or maybe watts ? Anybody know ? Since the plug configuration is dependent on the rating, maybe anything with an "L" shape plug should be compatable ? I'll dig through the junkyard in a little while and see what I have 1 Share this post Link to post Share on other sites
pfrederi 20,582 #13 Posted 26 minutes ago The big finned ones are usually either 10 or 15 amp just match the terminal pattern. 1 Share this post Link to post Share on other sites
