John c 223 #1 Posted May 29 (edited) I've got what I think may be a rectifier given up 1978 C101 8spd. K241 engine battery not charging when running, 12.65vdc when off 12.50vdc when running 12.35vdc running, headlights on Battery is new in good condition, As close to a manual as I have is one for magnum series Kohlers, based on that I read the following: Neither of the stator leads show shorted or grounded, about 2~3 ohms between them, and 34ish-vac output at full throttle. So I suspect the rectifier is at fault is there a chart showing points to test and values to expect to troubleshoot the rectifier ? I've got others laying around, so how interchangeable are they among other sizes engines Also how can you determine what amperage the stator is rated for ? Thanks, john Edited May 29 by John c Share this post Link to post Share on other sites
ri702bill 13,050 #2 Posted May 29 The rectifier housing must be grounded. Over time, oxidation builds up on the two mounting fasteners. Try jumping the housing to ground (not the fasteners) and retest. If it works, unmount it & clean the mounting area. Some of us add a ground wire between the rectifier housing and the screw head.... A freshly painted surface can cause issues too if the rectifier is attached to it... 3 1 Share this post Link to post Share on other sites
John c 223 #3 Posted May 30 OK, I'll try that tomorrow, this old machine has plenty of rust all over it, so this may be something. So is there a way to tell the rating of the alternator ...that doesn't involve taking the flywheel off the engine ? Share this post Link to post Share on other sites
Achto 32,687 #4 Posted May 30 27 minutes ago, John c said: So is there a way to tell the rating of the alternator ...that doesn't involve taking the flywheel off the engine ? The spec number on the engine should help get you this information. 2 Share this post Link to post Share on other sites
John c 223 #5 Posted May 30 the spec number on the engine is 46766d, anybody have a chart explaining what the number means ? Share this post Link to post Share on other sites
953 nut 69,285 #6 Posted May 30 The Spec. Number is located on the engine data plate, once you have that number you can be sure what parts are correct. Unless you are absolutely sure the engine is the one kit left the factory with you can't be sure just by using the year of the Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #7 Posted May 30 That specification number is assigned to identify how the engine was configured for the intended Kohler customer. The K241 engines have their own series of spec numbers. When you go to the parts list you will see in this case there are two different stators illustrated in it but only one is listed in the list - the one that the spec number specified. https://www.partstree.com/models/k241-46766-kohler-k-series-engine-made-for-wheel-horse-10hp-7-5kw/breaker-ignition-3/ Another way to identify the stator is to look at the location of the regulator terminals and their relationship to each other. The 10 amp and 15 amp are different. Here is where the original illustrated parts lists started. Take your spec number with you Share this post Link to post Share on other sites
953 nut 69,285 #8 Posted May 30 (edited) Your engine Spec Number shows it being a 1979 K-241 which is correct for the '79 C-101. Going into the K-241 parts manual Groupe 18 (charging and ignition) we find the number 114 applies to all components related to charging for that engine. You have a 15 amp charging system and the parts illustrated below are correct for your engine. We know that your stator is working properly based on the test you have done. Your voltage regulator / rectifier should be a 15 Amp unit. It has three tabs in an "L" pattern. I have attached a link to the parts manual for you. Edited May 30 by 953 nut add photo 2 Share this post Link to post Share on other sites
John c 223 #10 Posted May 30 (edited) Mine has the "L" shape connector plug, indicating a 15A charging system then I guess. So I started with simply adding a battery ground connection to the case of the rectifier with so change seen in voltage, so then I took it off completely cleaned all the electrical connections with fine sandpaper, contact cleaner and compressed air, also took the 3 wire connector plug apart and did the same thing. I added a wire from battery ground to under the bolted connection that holds the rectifier to the frame. Once back together I was seeing 13.65vdc with the engine running, but not a steady state 13.65, it slowly fell back to about 12.40, Once there it would maintain that level when adding load to it (headlights) The fact it holds voltage under load makes me think it's working, but then why won't it hold 13.5 +, and then the 12.4vdc looks to me like the ignition is running on the battery alone. Does my new ground sound sufficient and I do in fact have a defective rectifier ? Or should I add a tapped screw to one of the cooling fins on the rectifier to make grounded connection Any of you guys been down this path before ? Edited May 30 by John c Share this post Link to post Share on other sites
pfrederi 21,150 #11 Posted May 30 Sounds like time for a new rectifier.... 2 Share this post Link to post Share on other sites
John c 223 #12 Posted May 30 that's what I'm thinking too, How much interchangeability is there among these things, I've got several on hand, I suppose they're rated in amps or maybe watts ? Anybody know ? Since the plug configuration is dependent on the rating, maybe anything with an "L" shape plug should be compatable ? I'll dig through the junkyard in a little while and see what I have 1 Share this post Link to post Share on other sites
pfrederi 21,150 #13 Posted May 30 The big finned ones are usually either 10 or 15 amp just match the terminal pattern. 1 Share this post Link to post Share on other sites
John c 223 #14 Posted May 30 I took one off of a B80 exact look alike, does the exact same thing. Now is probably the perfect time to wonder if the ammeter delete would affect the recifier..... Share this post Link to post Share on other sites
pfrederi 21,150 #15 Posted May 30 Have you load tested your battery? So many problems in the electrical forum resolve to bad grounds or a bad battery Share this post Link to post Share on other sites
John c 223 #16 Posted May 30 No I've not, not really certain how to, besides taking it to the auto parts store. I could put the battery in another tractor and take some readings there, I've also got another recifier from a B100 I could try. Is the ammeter crucial to the proper operation of the charging system, the one that was in the C101 was kind of suspect, it looked like a ground fault waiting to happen, so I by passed it. Isn't there a diode inside the harness coming from the alternator, could that have a hand in this you think Share this post Link to post Share on other sites
pfrederi 21,150 #17 Posted May 30 Poor mans not so accurate load test. Hook up your multimeter ..should be 12.6 volts. Start cranking in voltage drops below 9 bad battery. Share this post Link to post Share on other sites
John c 223 #18 Posted May 31 The battery I'd thought was good, may well be NFG, yeah it was bought new last november, but it's layed around the shop all winter in and out of various machines and not much down time on charge. I'll move it into a machine and verify charging before hand to see how it responds. 1 Share this post Link to post Share on other sites
John c 223 #19 Posted June 2 well, I was able to figure this thing out, turns out the connections at the rectifier was the issue. I got my 314 in the shop and used it as a base to verify and eliminate, once I remade the connections I got it back to 13.6vdc at full throttle. While I was at it I tested 2 other unit I have to verify they work. I think I may want to take it back out, find some dremel bits and get a proper and thorough clean on the rectifier stabs, solder some pigtails on it then splice them back into the harness. Poor boys battery tester showed me my battery may still has some guts in it, after 4 15second crank cycles, it was holding at 11.4vdc. After that it ran about 13.65vdc at full throttle and was holding at 13.6 after spending the night plugged into a trickle charger. thanks for your help guys Share this post Link to post Share on other sites
953 nut 69,285 #20 Posted June 2 Del City sells the Packard 56 female connectors and a four terminal block that will slip right over the terminals on your regulator. https://www.delcity.net/store/wire-connectors-quick-splices/packard-56-series-electrical-connectors/female-4-contact/ https://www.delcity.net/store/wire-connectors-quick-splices/packard-56-series-electrical-connectors/female-terminals/ Share this post Link to post Share on other sites
John c 223 #21 Posted June 2 thank you Richard, I couldn't think of what those terminals were called to save my life the other day. 1 Share this post Link to post Share on other sites
