Fj40z
Possible C160
Fj40z
14 minutes ago, AlexR said:
Eb is right on, it's a 1976 and yes it was originally a C160 8 speed
Whats the breakdown on the numbers that lets you know that? Like to learn
oliver2-44
8 hours ago, Fj40z said:
Seller had replaced both rear axle seals not long ago as well.
Nice looking Horse!
Sometimes a leaking rear axle seal can indicate other issues.
Jack up the tractor, remove the rear wheels and see if you can move the axle hubs up/down, side to side. Any movement more than a tiny tiny amount can indicate worn axle bearings and or axles. New seals usually don’t last if the bearings are worn.
In an out movement is ok
Edited by oliver2-44
Fj40z
2 minutes ago, oliver2-44 said:
Nice looking Horse!
Thank you sir! I’ll sure do that as soon as I get a chance
ebinmaine
 Here’s a pic of the data tag. Any guesses to the model year?
Hard to see in the pic but it reads
61-16K801-03173
6311
The first 6 in the first line is what tells the year here.  I don't recall the methodology behind it.
AlexR
On the second line the 4 digits I believe the 6 is for 76 and 311 is the 311th day of 76
But there is something in the first line that determines the year as well I'm not completely sure what either.
The first line 61 is a indicator of the year in some way. The 16K is the 16hp kohler and the 8 is for the 8 speed
Edited by AlexR
ineedanother
61-16K801-03173
6311
Here is the tag from my first c-160. It's difficult to make out but:
61-16KS01-03388
6302
Possibly together on the production line in 1976. Almost certainly on the grounds together and might have come to NC in the same shipment.
Edited by ineedanother
Fj40z
61-16KS01-03388
6302
How cool is that!! I wouldn’t doubt it at all. Would be interesting to know what dealers they were sent to and such. I do know mine spent its entire life in western NC. Crazy to think after all those years they are both still in central NC now.
ineedanother
50 years of who knows what. The frame from mine is still here but was mistreated and unserviceable. Just about everything else from it is working for me still. That's a testament...:wh:
gwest_ca
Notice the plate stamper at the time did not understand Julian build dates
1976 C-160 8-Speed model 61-16K801
1976 serial numbers that have shown up for the 61-16K801
003173 - Build date 1975 5311 November 7 Friday [6311 is wrong]
1976 C-160 Auto model 61-16KS01
1976 serial numbers that have shown up for the 61-16KS01
003388 - Build date 1975 5302 October 29 Wednesday [6302 posted]
  • Excellent 2
ineedanother
Interesting, and I have yet to figure out how you decipher all of this but appreciate it :thumbs: Not to derail @Fj40z thread but I'm in agreement that we're both in possession of '75 c-160s regardless of the lack of details to confirm build dates. The one "record" I have from mine is a manual from the PO.
  • Heart 1
Fj40z
@ineedanother  please keep posting, all great info no derailment at all.
Fj40z
Very cool info with this. I’m still learning so I’m not 100 percent sure what Julian build dates mean. I’m thinking that it means both mine and @ineedanother have C160’s that were actually built in late 1975 for the 1976 model year correct?
ebinmaine
Julian dates are usually a 4 or 5 character code that shows the year made and the actual COUNTED day of that year.
For example:
January has 31 days
February usually has 28
March has 31
Add them. 90
So a Julian date for March 31st, 1975 might read
75090
Or
5090
That's my impression.  :handgestures-thumbupright:
Fj40z
@ebinmaine Makes sense, would have never figured that out on my own.
ebinmaine
Me either. That goes back to my early days in auto parts.
pfrederi
If you were in the Army and had anything to do with supply you know julian dates.  Problem was the 4 digit replicated every 10 years
peter lena
@Fj40z personally  love original  oiled patina , first thing  I do on  any recent pick up .  never remove any of  what's there , 2 stage set up , penetrating oil spray / soak down , really good in a hot  sun , to quickly depen base of  patina paint ,would just leave , enhance that soak for days , then I like a mineral oil clean cloth  rub down ,  get every inch  of  penetrated paint , let that soak , again , the sun really darkens the paint absorption, wipe it down  clean / clear , then a 6" electric palm buffer , cleaner wax , just go easy and you will see the depth  of what's left , experiment on areas , for  reference , why not ?  think that will be a perfect  darker  based look . deck will probably  be a stage cleaner / brighter . like to hot sun oil soak those , don't tell it doesn't work . pete
