kbert1171 2 #1 Posted May 29 Where can I find a set of blades for my '69 Raider 12 with a 42"deck? I see lots of blades, but none have the oblong center hole and the two smaller alignment holes on either side of the center bolt hole. (I believe it's a 42". Thought it was 48", but it's not.) Anyway, I need help, please. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #2 Posted May 29 42' side discharge. The rear gauge wheel adjuster is on the right side of 42" decks. Left side on 48" decks. 6693 blade replaced by 100200 3-blade kit and no longer available from Toro (Hole 5/8in.x3/4in. Double-D) Stens replacement for 6693 - 3 of 350-041 still available March 6, 2021 and they still come up with a Google search. Share this post Link to post Share on other sites
kbert1171 2 #3 Posted May 30 Gauge wheel adjuster? The deck adjustment wheel is on the right hand side, if that's what you're talking about. It's a 42c side discharge. And is the 350-041 the number I need to look up? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #4 Posted May 30 You should be able to use any of the numbers. 1 Share this post Link to post Share on other sites
peter lena 9,940 #5 Posted May 30 @kbert1171 how easily / smoothly do all related pulleys , spindles move / function ? great opportunity to insure smooth / quiet operation , your hand lever pto , is the proof of that ? would bet that there rough / noisy , whining bearings involved , another show of bearing issues is ? frayed belts , related bearings are usually cooked , lubrication failure . causes belts to bounce / buzz . just a heads up on a regular issue , pete Share this post Link to post Share on other sites
953 nut 67,376 #6 Posted May 30 https://sleequipment.com/products/stens-genuine-part-350-041-medium-lift-blade-pack-of-3?variant=44766799921333&country=US¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=23864821890&gbraid=0AAAAADsodPoyHvjNXVKUp5skNnCbsJR9y&gclid=Cj0KCQjwlerQBhDMARIsAB16H-WCOqsWLQWTBUs2qwWLGQZv92li8AXGvRmjb-eJvzN_2Kqe1dp-rCYaArA6EALw_wcB 1 Share this post Link to post Share on other sites
kbert1171 2 #7 Posted May 30 3 hours ago, 953 nut said: https://sleequipment.com/products/stens-genuine-part-350-041-medium-lift-blade-pack-of-3?variant=44766799921333&country=US¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gad_campaignid=23864821890&gbraid=0AAAAADsodPoyHvjNXVKUp5skNnCbsJR9y&gclid=Cj0KCQjwlerQBhDMARIsAB16H-WCOqsWLQWTBUs2qwWLGQZv92li8AXGvRmjb-eJvzN_2Kqe1dp-rCYaArA6EALw_wcB Thanks. These are much cheaper than the ones I found when looking for the numbers shared earlier. Share this post Link to post Share on other sites
