953 nut 66,411 #26 Posted Wednesday at 01:40 PM 1 hour ago, BHpa said: connect the two posts of the solenoid (bridging them with a screw driver) That tells you the cable from the solenoid to the starter is not the problem. Share this post Link to post Share on other sites
BHpa 9 #27 Posted Wednesday at 03:04 PM 1 hour ago, 953 nut said: That tells you the cable from the solenoid to the starter is not the problem. Do you think this would also eliminate any issue with the PTO switch, since it starts to crank? I would assume if the PTO switch/sensor or whatever was bad to keep it from cranking it would also prevent it in this scenario too, right? Share this post Link to post Share on other sites
Handy Don 16,725 #28 Posted Wednesday at 03:30 PM 22 minutes ago, BHpa said: Do you think this would also eliminate any issue with the PTO switch, since it starts to crank? I would assume if the PTO switch/sensor or whatever was bad to keep it from cranking it would also prevent it in this scenario too, right? No. By jumping the solenoid terminals you circumvented ALL of the safety switches. It tells you only that once the starting circuit is correct, there is power at the solenoid to crank the engine. Note that getting the engine to crank and having the ignition to keep it running are two different circuits. 1 1 Share this post Link to post Share on other sites
Razorback 1,337 #29 Posted Wednesday at 08:22 PM My C160's safety circuit is simple compared to your newer Horse, but when I first encountered my C160 it didn't want to start reliably. It boiled down to the safety switch at the PTO lever not getting engaged when the lever was in the OFF position. After getting awesome help from this site's participants along with a wiring diagram for my tractor, it was just a process of elimination going through the safety circuit using a multimeter. If you don't have one of those, I would highly suggest you get one and learn to use it. A simple continuity test will get you on the correct path. Keep at it...... you'll get it! 2 Share this post Link to post Share on other sites
953 nut 66,411 #30 Posted Wednesday at 10:53 PM On 5/30/2026 at 12:41 PM, BHpa said: jump the orange and black wires together through the housing but it didn't make any difference - still nothing. I'm not entirely sure it made a good connection, but I think so. The BLACK and ORANGE seat switch wires being joined together with the PTO on will prevent the magneto from producing a spark, just like the operator leaving the seat. On 5/31/2026 at 8:21 PM, 953 nut said: Place your shift lever in neutral and block the tires so the tractor can't move. Now take a small jumper wire from the battery "+" terminal to the small purple wire on the solenoid. If the starter turns over the solenoid is working. What was the outcome of performing this test? 1 Share this post Link to post Share on other sites
BHpa 9 #31 Posted Thursday at 01:39 PM 14 hours ago, 953 nut said: The BLACK and ORANGE seat switch wires being joined together with the PTO on will prevent the magneto from producing a spark, just like the operator leaving the seat. What was the outcome of performing this test? Unfortunately, I haven't had time for that yet. I plan on getting back at it on Friday evening - end of the school year stuff for the kids has the evenings booked up. 1 Share this post Link to post Share on other sites
BHpa 9 #32 Posted Saturday at 01:06 AM On 6/3/2026 at 6:53 PM, 953 nut said: What was the outcome of performing this test? Finally got a chance to work through that list of tests. The only one I didn't do was the second to last one about checking the ground because I was a bit confused about the jumpers and terminals. But I did the final one in testing the ignition switch. When I tried jumping the terminals that were connected to B and S nothing happened. Is there a further test to see if the ignition switch is bad or does that likely narrow it down? Thanks for these tips, it was very helpful. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,263 #33 Posted Saturday at 12:15 PM Share this post Link to post Share on other sites
953 nut 66,411 #34 Posted Saturday at 12:24 PM On 5/31/2026 at 8:21 PM, 953 nut said: Place your shift lever in neutral and block the tires so the tractor can't move. Now take a small jumper wire from the battery "+" terminal to the small purple wire on the solenoid. If the starter turns over the solenoid is working. Did the starter turn over with this test? Share this post Link to post Share on other sites
953 nut 66,411 #35 Posted Saturday at 12:27 PM (edited) Double posted. Edited Saturday at 12:29 PM by 953 nut Share this post Link to post Share on other sites
BHpa 9 #36 Posted 8 hours ago On 6/6/2026 at 8:24 AM, 953 nut said: Did the starter turn over with this test? Sorry, I had missed this one. Just did it today - I believe so - if I did it right. I used a small jumper wire to connect the + line from the battery to the terminal on the solenoid that the purple is connected to - this turned the starter over. HOWEVER (and I'm not sure if this is what you meant) when I used the same jumper from the + terminal to the purple wire itself (disconnected from the solenoid - wire inserted in to plastic clasp end of the purple wire) nothing happened. Sorry if I'm not understanding it correctly. Share this post Link to post Share on other sites
953 nut 66,411 #37 Posted 2 hours ago 5 hours ago, BHpa said: I used a small jumper wire to connect the + line from the battery to the terminal on the solenoid that the purple is connected to - this turned the starter over. This proves that the solenoid is functioning properly. The purple wire provides a path FROM the ignition switch to the soleniod if; the 25 Amp Fuse is good, the Key Switch is in the START position. the engine oil level is good, the PTO is not in the operate position, and The clutch is depressed. Share this post Link to post Share on other sites
