BHpa
Safety Switch Issue
953 nut
1 hour ago, BHpa said:
connect the two posts of the solenoid (bridging them with a screw driver)
That tells you the cable from the solenoid to the starter is not the problem.
BHpa
Do you think this would also eliminate any issue with the PTO switch, since it starts to crank?  I would assume if the PTO switch/sensor or whatever was bad to keep it from cranking it would also prevent it in this scenario too, right?
Handy Don
No. By jumping the solenoid terminals you circumvented ALL of the safety switches. It tells you only that once the starting circuit is correct, there is power at the solenoid to crank the engine.
Note that getting the engine to crank and having the ignition to keep it running are two different circuits.
Razorback
My C160's safety circuit is simple compared to your newer Horse, but when I first encountered my C160 it didn't want to start reliably. It boiled down to the safety switch at the PTO lever not getting engaged when the lever was in the OFF position. After getting awesome help from this site's participants along with a wiring diagram for my tractor, it was just a process of elimination going through the safety circuit using a multimeter. If you don't have one of those, I would highly suggest you get one and learn to use it. A simple continuity test will get you on the correct path.
Keep at it...... you'll get it!
  • Excellent 2
953 nut
On 5/30/2026 at 12:41 PM, BHpa said:
jump the orange and black wires together through the housing but it didn't make any difference - still nothing.  I'm not entirely sure it made a good connection, but I think so.
The BLACK and ORANGE seat switch wires being joined together with the PTO on will prevent the magneto from producing a spark, just like the operator leaving the seat.
On 5/31/2026 at 8:21 PM, 953 nut said:
Place your shift lever in neutral and block the tires so the tractor can't move. Now take a small jumper wire from the battery "+" terminal to the small purple wire on the solenoid. If the starter turns over the solenoid is working.
What was the outcome of performing this test?
BHpa
Unfortunately, I haven't had time for that yet.  I plan on getting back at it on Friday evening - end of the school year stuff for the kids has the evenings booked up.
BHpa
Finally got a chance to work through that list of tests. The only one I didn't do was the second to last one about checking the ground because I was a bit confused about the jumpers and terminals.  But I did the final one in testing the ignition switch.  When I tried jumping the terminals that were connected to B and S nothing happened.  Is there a further test to see if the ignition switch is bad or does that likely narrow it down?
Thanks for these tips, it was very helpful.
