Beap52 2,424 #1 Posted May 22 Nothing like the slapping of vacuum wipers on a deary day. Drove the '47 Chevy to town and began to sprinkle on way home. Don't get to use the wipers much. 20260522_093425.mp4 4 3 Share this post Link to post Share on other sites
ebinmaine 80,062 #2 Posted May 22 Only seen those in-person once. A friend of my Ole Man's had a cabover Freightliner with vacuum wipers. 3 Share this post Link to post Share on other sites
squonk 47,695 #3 Posted May 22 My 61 Falcon had them. Touch the gas and they stopped! 3 Share this post Link to post Share on other sites
ri702bill 12,688 #4 Posted May 22 My 57 Chevy 210 had them. As they say, vacuun sucks. They were "adjustable" to a point for swipes per minute.... almost non existant while struggling up a long incline, and they try to beat themselves to death going on the down incline. Much worse with a worn engine that did not generate good vacuum. I do NOT miss them... 4 Share this post Link to post Share on other sites
953 nut 68,121 #5 Posted May 22 Adding a vacuum reservoir to the line going to the wiper motor would help. 5 1 Share this post Link to post Share on other sites
ineedanother 2,767 #6 Posted May 22 One of my first trucks was a '48 Chevy. Wipers were for downhill runs. Uphill, not so much. 3 1 Share this post Link to post Share on other sites
lynnmor 8,966 #7 Posted May 23 I had a Rambler station wagon with vacuum wipers, they were assisted by the fuel pump with a diaphragm vacuum pump incorporated in it. 4 Share this post Link to post Share on other sites
ri702bill 12,688 #8 Posted May 23 9 hours ago, lynnmor said: I had a Rambler station wagon with vacuum wipers, they were assisted by the fuel pump with a diaphragm vacuum pump incorporated in it. Kelvinator to the rescue! Share this post Link to post Share on other sites
Racinbob 13,082 #9 Posted May 23 14 hours ago, 953 nut said: Adding a vacuum reservoir to the line going to the wiper motor would help. When I was in high school my mom drove a 1960 T-Bird. I remember it having a reservoir on the vac wipers. It looked like a sealed coffee can with two vacuum hose fittings and was painted Ford engine blue. I just looked at a bunch of engine compartment pictures and couldn't find one. I wonder if it was aftermarket or homemade. It must of helped but I remember countless times when I needed to nail the gas in the rain. Not good. 1 Share this post Link to post Share on other sites
953 nut 68,121 #10 Posted May 23 1 hour ago, Racinbob said: I remember it having a reservoir on the vac wipers. It looked like a sealed coffee can with two vacuum hose fittings and was painted Ford engine blue. They are made of plastic now and have a check valve on the input line. A few years back my wife was complaining about the AC cutting off and switching to heat while she was driving. It never occurred when I was driving, we took it to two dealers since it was under warranty and neither one could find the problem. Johnny, the mechanic at our Goodyear store, went for a test drive with me, then we swapped sides and he drove putting the pedal to the metal and sure enough, the AC changed over to heat. Guess the wife is a bit more aggressive behind the wheel than I am. The following day Johnny had the new reservoir and it was off to the races with cool AC for the wife. 2 Share this post Link to post Share on other sites
squonk 47,695 #11 Posted May 23 The "coffee can " resi was indeed oem back in the day but they rusted out. Went to the shot put style tank. My Falcon wipers were off the fuel pump. The HVAC system defaults to defrost with loss of vacuum so that explains why it was switching. And for some reason, mice liked to eat the colorful vacuum hoses under the dash of Chrysler 5th Avenues! 3 Share this post Link to post Share on other sites
Handy Don 17,163 #12 Posted May 23 Have modern vehicles switched to electric actuators for redirecting airflow? Share this post Link to post Share on other sites
lynnmor 8,966 #13 Posted May 23 5 minutes ago, Handy Don said: Have modern vehicles switched to electric actuators for redirecting airflow? I bought a new Tahoe in 2001, with the new body style they went with electric. First snowmobiling trip to Maine with it my wife had to keep a coat over her legs. Long, long story about the problem ended with factory involvement, another dealer and one month with the entire dash tore apart. The fix was to throw away the cheap plastic gear and use a metal one. Whenever there is a loss of battery power, the actuator cycles both ways till it stalls and calibrates to those stops, of course breaking the plastic gear in the process. To this day the fix is undocumented so they don't have to fix them all. 2 Share this post Link to post Share on other sites
adsm08 4,890 #14 Posted May 23 22 minutes ago, Handy Don said: Have modern vehicles switched to electric actuators for redirecting airflow? Ford switched around 2004-2006 depending on the model. Not sure when other manufacturers made the switch. 1 Share this post Link to post Share on other sites
cafoose 3,785 #15 Posted May 23 (edited) My 2014 Tundra makes this noise after I shut it off a minute or so later. Wondering if it's vacuum related? Did it as long as I owned it with no issues related to it. Seems normal. Kind of like a growling stomach Edited May 23 by cafoose Share this post Link to post Share on other sites
gt14rider 1,275 #16 Posted May 23 Hi all, I haf a 60's VW bug, when i got it, it ran good, had vacuun wipers ,worked had a storm, and thay quit working couple miles from home , next day got a flat ,went to change it ,it was flat,. The vacuum line was hook up to the spare, used up the air ,no wipers and a flat tire 3 1 Share this post Link to post Share on other sites
Handy Don 17,163 #17 Posted May 23 1 hour ago, gt14rider said: Hi all, I haf a 60's VW bug, when i got it, it ran good, had vacuun wipers ,worked had a storm, and thay quit working couple miles from home , next day got a flat ,went to change it ,it was flat,. The vacuum line was hook up to the spare, used up the air ,no wipers and a flat tire I also had a mid-60’s Bug. That wasn’t the vacuum line connected to the spare, it was the washer fluid reservoir. There was no pump--when you filled the reservoir with washer fluid, you also pumped it up with pressure OR connected it to the spare tire (for pressure, not vacuum). If you did the spare tire route and then kept pressing the washer button when there was no fluid to deliver, eventually you took all the pressure out of the spare. 2 Share this post Link to post Share on other sites
adsm08 4,890 #18 Posted May 23 3 hours ago, gt14rider said: Hi all, I haf a 60's VW bug, when i got it, it ran good, had vacuun wipers ,worked had a storm, and thay quit working couple miles from home , next day got a flat ,went to change it ,it was flat,. The vacuum line was hook up to the spare, used up the air ,no wipers and a flat tire I get the impression that you do not have a firm grasp on the differences between pressure and vacuum. Share this post Link to post Share on other sites
gt14rider 1,275 #19 Posted May 23 Thay say the mind is the first to go, give me a break its been 48 years. 2 Share this post Link to post Share on other sites
