New2WH 3 #1 Posted May 20 Recently acquired C-161 16hp Wheel Horse. It appears the clutch plate is wiped out. Where can I get a service manual that shows the parts break down for this assy. Any help on where I can find the model and s/n tag? Are parts still made for Wheel Horse? Thanks 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #2 Posted May 20 Welcome to Red Square. This link shows where the ID tags were in 1978. That is the steering fan gear in the background. An odd location and they did not stay there for long. This is the 12 hp model but tag location will be the same. The tag should have the model number, serial number a 4-digit build date. Click on the fuzzy picture in this link. 2 2 Share this post Link to post Share on other sites
953 nut 69,287 #5 Posted May 21 20 hours ago, New2WH said: Any help We are here to help one another. As you can see by the response to your inquiry we have lots of information to share. Please take a couple of minutes and tell us about your Wheel Horse story. https://www.wheelhorseforum.com/forum/47-introductions/ 1 Share this post Link to post Share on other sites
peter lena 10,065 #6 Posted May 21 @ NEW 2 WH , most important question ? what's causing the , plate wear / drag ? bet its COLLECTIVE LUBRICATION / FAILURE , most of the units I see , have belt drives that barely function , ironically once converted , that set up is truly amazingly smooth , easy in its function . most immediate show of that ? mule drive belt , from engine down to frame pulley mount , mine move move easily by hand , no rough , erratic function , also frayed belts will tell you that , just a heads up on the repetitive failure , pete Share this post Link to post Share on other sites
New2WH 3 #7 Posted May 21 Thank you all for your response. I was told by previous owner that the clutch gave out while snow blowing (hitting ice) I will take a look for the model/serial number Share this post Link to post Share on other sites
New2WH 3 #8 Posted May 28 On 5/21/2026 at 7:34 AM, 953 nut said: We are here to help one another. As you can see by the response to your inquiry we have lots of information to share. Please take a couple of minutes and tell us about your Wheel Horse story. https://www.wheelhorseforum.com/forum/47-introductions/ All contributions have been a big help, I really appreciate all the knowledge! Ordered a clutch plate waiting for it to arrive. Changed all the fluids and fixed a couple of wires that the mice munched on. The engine is turning over but I am not getting any spark. Engine info attached. any thoughts on where to look. I am getting 12v at the + terminal on the coil and the lead going to the points. Share this post Link to post Share on other sites
wallfish 20,607 #9 Posted May 28 3 hours ago, New2WH said: any thoughts on where to look. Clean the contacts on the points Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #10 Posted May 28 Your tractor is a 1986 416-8 model 31-16K802 unless it has a newer engine. The engine was made in 1985 but the 1986 model year was the only year to use spec. 71318 This link will take you to 2 pages of search results for this model number https://www.wheelhorseforum.com/search/?q=31-16k802&quick=1&type=downloads_file Share this post Link to post Share on other sites
New2WH 3 #11 Posted May 29 13 hours ago, wallfish said: Clean the contacts on the points Wallfish Thanks for info, did try that already Share this post Link to post Share on other sites
New2WH 3 #12 Posted May 29 13 hours ago, gwest_ca said: Your tractor is a 1986 416-8 model 31-16K802 unless it has a newer engine. The engine was made in 1985 but the 1986 model year was the only year to use spec. 71318 This link will take you to 2 pages of search results for this model number https://www.wheelhorseforum.com/search/?q=31-16k802&quick=1&type=downloads_file I am pretty sure I have a Frankenstein wheel horse. model number on tractor is 91-08K802-9748 8319 which believe had an 8HP. This unit has a 16HP. Thanks for identifying 1986 as the engine date. Any idea what the mfg date is for the tractor? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #13 Posted May 29 40 minutes ago, New2WH said: Any idea what the mfg date is for the tractor? Serial 9748 - Build date 1978 8319 November 15 Wednesday Share this post Link to post Share on other sites
New2WH 3 #14 Posted June 9 On 5/29/2026 at 10:14 AM, gwest_ca said: Serial 9748 - Build date 1978 8319 November 15 Wednesday UPDATE 06/09/2026 We finally got her running! Replaced points, coil, spark plug and spark plug wire. Setting the points was quite touchy but finally got it. Received PTO clutch plate worked great. Got the mower deck cleaned up and attached. She is cutting grass. Thank you everyone for your help! On 5/28/2026 at 7:30 PM, gwest_ca said: Your tractor is a 1986 416-8 model 31-16K802 unless it has a newer engine. The engine was made in 1985 but the 1986 model year was the only year to use spec. 71318 This link will take you to 2 pages of search results for this model number https://www.wheelhorseforum.com/search/?q=31-16k802&quick=1&type=downloads_file I am pretty sure I have a Frankenstein wheel horse. model number on tractor is 91-08K802-9748 8319 which believe had an 8HP. This unit has a 16HP. Thanks for identifying 1986 as the engine date. Any idea what the mfg date is for the tractor? 1 Share this post Link to post Share on other sites
