1968Commando 189 #1 Posted May 20 Hello all, yesterday I dropped my zero turn off at the dealer because it’s broken 😠 anyway I spotted a red snow plow..it’s wheel horse plow, I believe it’s probably a 90s or 80s one, are these plowed pretty interchangeable or not really? Can get serial number for you Share this post Link to post Share on other sites
ebinmaine 80,263 #2 Posted May 20 Have to have a serial number to tell for sure. If it fits a 300 or 400 series or any C Series then it will fit your commando. If it's built for a 200 series, not so. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #3 Posted May 20 Numbers would help. There were 2 available in 1968. The old style 6-2111 mounted ahead of the rear axle housing as did the models for the short frame tractors. The new style 6-4111 mounts under the rear axle housing and fits both short and long frame tractors. Here is list of what you are looking for. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - Lift bracket behind crossmember 7716 A-frame - replaced by 1969 model [6-4112 + 6-9621] - First to have the lift bracket ahead of the crossmember 7716 A-frame 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 (1968 model 6-4111 to 1980 model 06-42BC01 use the same 7716 A-frame assembly but the lift tab changed according to the ipl's) 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) (Uses 104341 and 3771 index wires - See file for dimensions) 1984-1989 model 06-48BC01 (They are now 48" wide) (Uses 104341 and 3771 index wires - See file for dimensions) [M] 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) 1 Share this post Link to post Share on other sites
1968Commando 189 #4 Posted May 20 14 minutes ago, ebinmaine said: Have to have a serial number to tell for sure. If it fits a 300 or 400 series or any C Series then it will fit your commando. If it's built for a 200 series, not so. What would be the difference Share this post Link to post Share on other sites
ebinmaine 80,263 #5 Posted May 20 14 minutes ago, 1968Commando said: What would be the difference Different mounting style entirely Share this post Link to post Share on other sites
Handy Don 17,305 #6 Posted May 20 13 minutes ago, 1968Commando said: What would be the difference Different tractor frame and transaxle made for different styles of blade frames. if you can post a picture of the blade/frame, we’ll ID it for you Share this post Link to post Share on other sites
1968Commando 189 #7 Posted May 20 30 minutes ago, Handy Don said: Different tractor frame and transaxle made for different styles of blade frames. if you can post a picture of the blade/frame, we’ll ID it for you I’ll get some today, hopefully they let it go! Share this post Link to post Share on other sites
1968Commando 189 #8 Posted May 20 31 minutes ago, ebinmaine said: Different mounting style entirely Gotcha thank you! Share this post Link to post Share on other sites
squonk 47,885 #9 Posted May 21 18 hours ago, 1968Commando said: What would be the difference Some 200 series blades mount on the front of the front axle Share this post Link to post Share on other sites
