Chris689 323 #1 Posted May 18 So while I was mowing my lawn yesterday my C120 was running great. Until I stopped to move a soccer ball. Turned the mower off, idled it down, hopped off and moved the ball, got back on and throttled up and it does. It struggled to start but started none the less and I continued on thinking that was weird. 20 minutes later the warden calls. Stop the mower, idle down and answer the phone. Finish the call and throttle up and it dies again but this time won’t start. Checked spark, not the problem, pulled the fuel line put my thumb over it and cranked, felt the pump working, removed my thumb and it started pushing fuel. Reconnected and continued on. has anyone had a similar issue? It never stalled while running just when going from idle to full throttle after being at full throttle for a bit. Share this post Link to post Share on other sites
SylvanLakeWH 32,514 #2 Posted May 18 Check gas cap vent...? 1 1 Share this post Link to post Share on other sites
ri702bill 13,067 #3 Posted May 18 Dad's 702 was a 4 season worker for him. It does not smoke, but will oil / carbon buildup foul the spark plug. It will run , then poorly until you shut it down. Then the spark grounds out to the plug shell thru thru the buildup. Pull the plug, clean it & reinstall - almost good as new. Note that using an inline zenon bulb tester WILL show that it has spark - it just does not bridge the plug gap... 1 Share this post Link to post Share on other sites
Chris689 323 #4 Posted May 19 14 hours ago, SylvanLakeWH said: Check gas cap vent I’m probably gonna check that this evening. 14 hours ago, ri702bill said: Dad's 702 was a 4 season worker for him. It does not smoke, but will oil / carbon buildup foul the spark plug. It will run , then poorly until you shut it down. Then the spark grounds out to the plug shell thru thru the buildup. Pull the plug, clean it & reinstall - almost good as new. Note that using an inline zenon bulb tester WILL show that it has spark - it just does not bridge the plug gap... so I may replace the plug, it was in okay shape but I’ve never changed it in the two years I’ve owned it. I’ve never had good luck with those testers so I just ground it to the sheet metal and spark was jumping the gap as it should. Share this post Link to post Share on other sites
pfrederi 21,150 #5 Posted May 19 1 hour ago, Chris689 said: I’m probably gonna check that this evening. so I may replace the plug, it was in okay shape but I’ve never changed it in the two years I’ve owned it. I’ve never had good luck with those testers so I just ground it to the sheet metal and spark was jumping the gap as it should. Plugs that seem to fire on the head will actually not be firing when they are under compression 1 1 Share this post Link to post Share on other sites
Chris689 323 #6 Posted May 19 17 minutes ago, pfrederi said: Plugs that seem to fire on the head will actually not be firing when they are under compression Good point. I’ve heard that but never actually seen it. Thank you for mentioning that Share this post Link to post Share on other sites
lynnmor 9,040 #7 Posted May 19 7 hours ago, pfrederi said: Plugs that seem to fire on the head will actually not be firing when they are under compression I keep an old plug that is gapped about twice the specification to allow for the compression factor. Not a perfect test but it is good enough most of the time. 2 Share this post Link to post Share on other sites
953 nut 69,313 #8 Posted May 20 Disconnect the wire to the condenser and see if the symptoms go away. An engine will run without the condenser, it is there to protect the points from burning. If an engine idles well, but runs erratically when revved up, like it hits and misses, pops and backfires, then chances are, it needs a new condenser/capacitor. And always install a condenser/capacitor with the wire facing downward so rain water and/or when washing off engine, water will not enter inside condenser/capacitor, ruining it. With water inside the condenser, this will also allow it to idle well, but cause it to run erratically when revved up. 3 1 Share this post Link to post Share on other sites
Chris689 323 #9 Posted May 23 So I’m 95% sure it was in fact the spark plug. Replaced the plug this morning and mowed this afternoon with no issue. I say 95% sure because it was cooler today than the last time I mowed so it not an exact test. However I did stop multiple times and idle it down for a minute and throttle back up and it had no problems going back to full throttle unlike the last time. I’ve never had a spark plug only fail sometimes so this was a new one for me. So thank you all for your help I really appreciate it. 1 Share this post Link to post Share on other sites
