squonk 47,701 #1 Posted May 16 We've all read our operating manuals. HA! YEAH RIGHT!!! They all say check all fasteners before operating! Well I was out mowing with the Wheel a Matic and Dino deck and I got to noticing how low it was cutting. Then I saw both "special 7/16-20 shoulder bolts had fallen out that hold the height adjusting rod!!! I had 1 spare so I had to go to the parts room and get a wheel lug bolt and lug nut to secure the adjuster! 4 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #2 Posted May 16 Timely post Mike. I was mowing with the 48"SD on the 312H Monday when the engine started to bog down. I flipped the PTO off as I stopped. When I looked behind the center blade was scalping the grass. The center spindle bolt and pulley had come loose and allowed the center blade to drop down. All back together and torqued all three spindle bolts. 3 Share this post Link to post Share on other sites
ri702bill 12,688 #3 Posted May 16 Yup, heat & vibration make for atroublesome tag team. If only they moved further up to the steering wheel hub and shaft...... My first rider was a 6 HP Sears go-cart style one with the engine between you legs. It was the de-luxe model with a blade engagement clutch. The PO had removed the blade for sharpening so many times that the threads in the aluminum hub were shot.... I went to mow, reved the engine, engaged the blare & it fell to the ground. Could have done a lot worse.... Share this post Link to post Share on other sites
Kenneth R Cluley 690 #4 Posted May 16 Lost part of the deck belt tensioner while mowing. Was out in yard with "construction magnet" dragging around yard , looked across and neighbor is looking at me like i've got three eyes, and asks what in the he$$ are you doing? I did eventually find the part. 2 3 Share this post Link to post Share on other sites
Ed Kennell 46,792 #5 Posted May 16 53 minutes ago, Kenneth R Cluley said: "construction magnet" dragging around yard I was lucky when the center spindle bolt washer and pulley came off. The old style 48" deck with the stiffener rib that surrounds the deck belt area kept every thing inside. I did search the grass where it came off before I found everything when I took the deck off. 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #6 Posted May 16 Seems quite a few of us have loose nuts. 1 7 Share this post Link to post Share on other sites
squonk 47,701 #7 Posted May 16 37 minutes ago, Ed Kennell said: Seems quite a few of us have loose nuts. " Behind the wheel!" 1 Share this post Link to post Share on other sites
ri702bill 12,688 #8 Posted May 16 4 hours ago, Kenneth R Cluley said: Was out in yard with "construction magnet" dragging around yard Got one of those - works great for steel chips off the lathe or milling machine - but no go for aluminum!! 1 Share this post Link to post Share on other sites
