Razorback 1,370 #1 Posted May 15 Regarding Kohler K series rear oil seal p/n 4703207: I found that NAPA has a seal that says it replaces that part..... NAPA Part #: SME 704003 NAPA seal, replacement for Kohler 4703207 I have one coming Saturday..... priced today at $7.71. I'll report back when I get it installed to comment about the fit...... then follow up later when I get some run time on it. (I had an oil leak on my Cub Cadet 123 that has a K301 in it. This will also apply to my Wheel Horse C160, and will apply to any K series engines that use 4703207) 4 Share this post Link to post Share on other sites
WHX?? 58,136 #3 Posted May 15 As long as the ID/OD and thickness match up. 2 Share this post Link to post Share on other sites
Razorback 1,370 #4 Posted May 15 (edited) 45 minutes ago, WHX?? said: As long as the ID/OD and thickness match up. One can only hope…. I.D.: 1.500" O.D.: 2.378" W: .250" Specifications Brand NAPA Replaces OE Part # 47-032-07 Engine Manufacturer Kohler Engine HP Rating 10 hp VMRS Code 065004020 Outside Diameter 2.378 in Width 0.25 Fits Engine Model # K241 Edited May 15 by Razorback Share this post Link to post Share on other sites
Andy N. 2,812 #5 Posted May 15 11 hours ago, Razorback said: I have one coming Saturday..... priced today at $7.71. Good find. I just ordered one from Amazon for $12 yesterday morning and it won't be here until 5/20. Share this post Link to post Share on other sites
squonk 48,125 #6 Posted May 15 1 hour ago, WHX?? said: As long as the ID/OD and thickness match up. In actuality it's the Kohler # Share this post Link to post Share on other sites
Razorback 1,370 #7 Posted May 15 1 hour ago, squonk said: In actuality it's the Kohler # I don’t understand…. Please elaborate. Share this post Link to post Share on other sites
WHX?? 58,136 #8 Posted May 15 1 hour ago, squonk said: In actuality it's the Kohler # 35 minutes ago, Razorback said: I don’t understand…. Please elaborate. Really ... watch you talkin about willis .... Share this post Link to post Share on other sites
squonk 48,125 #9 Posted May 15 ( I saw the Kohler # and knew for the past year and a half all Napa small engine uses O.E. #s') 47-032-07S is the Kohler #. All Napa small engine has switched to Kohler #'s without the dashes and S at the end. You are probably getting some old stock that has been sitting around at a Napa Warehouse still in the old Primeline/Napa Small Engine package. For example The 704003 shows 1 in the Buffalo Dist. Center and 1 in Carlisle. That's it for the NE. They may not even stock the Kohler # in the future. Who knows. I used the Napa/ Primeline products for years with good results. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #10 Posted May 15 I have always wondered about the crank seals. Normally I can cross reference all the seals on my WHs to CR/skf...but not the crank shaft seals... Share this post Link to post Share on other sites
Razorback 1,370 #11 Posted May 16 Picked up the seal just now….. it’s the PrimeLine part…. Now, to get the engine back together. Will do that after we get the yard mowed. Share this post Link to post Share on other sites
