Retired Wrencher 6,989 #1 Posted May 14 I just got this 1057 back up and running this spring went through it front to back.. I noticed a few weeks ago. It’s starting to make this lower end rattling noise. I was told could be the balance gears in the engine, but this one has no gears in it so I’m gonna give you a couple videos to listen to again, excuse my video taking skills. Any thoughts are welcome. IMG_1135.mov IMG_1134.mov Share this post Link to post Share on other sites
squonk 48,125 #2 Posted May 14 (edited) I have a K321 with the gears removed that was professionally rebuilt. Has about 30 hours on it and has the same noise. I'm not worried about it. Edited May 14 by squonk 1 Share this post Link to post Share on other sites
lynnmor 9,040 #3 Posted May 14 Might be piston slap, are you using the same oil as before? Any chance that gasoline got into the oil? Does it change as the temperature changes or the engine warms? 1 Share this post Link to post Share on other sites
rick 316 #4 Posted May 14 Are the engine mounting bolts still tight? I fixed a similar noise by tightening said bolts on my 314-8. Share this post Link to post Share on other sites
Lagersolut 802 #5 Posted May 14 3 hours ago, squonk said: I have a K321 with the gears removed that was professionally rebuilt. Has about 30 hours on it and has the same noise. I'm not worried about it. Same with the C 101 in my profile picture 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #6 Posted May 14 4 hours ago, squonk said: I have a K321 with the gears removed that was professionally rebuilt. Has about 30 hours on it and has the same noise. I'm not worried about it. Thanks Mike.I have never heard this before. And I have had a few of these engines. How many do you have on this engine? Do you use the engine a Lot or not much? Share this post Link to post Share on other sites
Retired Wrencher 6,989 #7 Posted May 14 1 hour ago, Lagersolut said: Same with the C 101 in my profile picture Thanks for the reply. 1 Share this post Link to post Share on other sites
squonk 48,125 #8 Posted May 14 Just now, Retired Wrencher said: Thanks Mike.I have never heard this before. And I have had a few of these engines. How many do you have on this engine? Do you use the engine a Lot or not much? I plow snow with it. It's on my 953 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #9 Posted May 14 1 hour ago, rick said: Are the engine mounting bolts still tight? I fixed a similar noise by tightening said bolts on my 314-8. I had this engine off the tractor for at least to years sitting on a a rolling cart. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #10 Posted May 14 1 minute ago, squonk said: I plow snow with it. It's on my 953 OK MIKE I feel better knowing that you think it is ok to use. I know a lot but ,not a master of engines. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #11 Posted May 14 4 hours ago, lynnmor said: Might be piston slap, are you using the same oil as before? Any chance that gasoline got into the oil? Does it change as the temperature changes or the engine warms? I think Mike answered this question. Share this post Link to post Share on other sites
squonk 48,125 #12 Posted May 14 The noise is very similar to piston slap or wrist pin. Back in the day when I was in the auto shop we had tons of GM and Chrysler 4 bangers that would rattle under a light load like de-acceleration. They pretty much ran forever. The few I had apart had loose wrist pins. Now My C-160 had this noise for years. One spring it got noticeably louder. So I swapped it out with another engine. I found a balance gear needle in the pan and this broken piston. It's a simple job to remove the head or pan and take a look inside if you're not sure. Share this post Link to post Share on other sites
Retired Wrencher 6,989 #13 Posted May 15 Thanks for the info Mike. This will be lightly used.It will be a ride up the street with a cold one in hand. Cheers! Share this post Link to post Share on other sites
Retired Wrencher 6,989 #14 Posted May 15 18 hours ago, rick said: Are the engine mounting bolts still tight? I fixed a similar noise by tightening said bolts on my 314-8. I will look into that. But I think there tight. Share this post Link to post Share on other sites
sqrlgtr 3,932 #15 Posted May 15 4 hours ago, Retired Wrencher said: Thanks for the info Mike. This will be lightly used.It will be a ride up the street with a cold one in hand. Cheers! I have noticed the more cold ones that go up and down the street the quieter they get . Share this post Link to post Share on other sites
Retired Wrencher 6,989 #16 Posted May 16 19 hours ago, sqrlgtr said: I have noticed the more cold ones that go up and down the street the quieter they get . sqrlgtr a big LOL on that It is a mans right to have a few cold ones every now and then. Share this post Link to post Share on other sites
