BR2 3 #1 Posted May 12 New to the group and Wheel Horse mowers. Looking for some in put on drain plugs on hydro pump and transaxle.. would like to service them before run it to much. Share this post Link to post Share on other sites
JoeM 10,120 #2 Posted May 12 If the machine has the Eaton 11 (has a spin on oil filter on the left side under the seat pan) the drain plug is the main plug located under the rear housing and requires a 1/4" hex wrench. If it has the Eaton 7, (no oil filter) This transmission has two separate oil compartments. One is the hydro (10w-30 oil) that is dedicated to hydro pump and is captive. The other is rear gearing lubrication. Takes 80w-90 and drains from the main plug located under the rear housing and requires a 1/4" hex wrench. The Eaton 7 hydro system can be drained and refilled. The drain plug is an o-ring plug located under the pump unit on the right side. 4 1 Share this post Link to post Share on other sites
Ed Kennell 46,792 #3 Posted May 12 (edited) I have always found the Eaton 700 in the ***A tractors and the Eaton 1100 in the ***H tractors. Edited May 12 by Ed Kennell 2 1 Share this post Link to post Share on other sites
953 nut 68,131 #4 Posted May 12 1 hour ago, Ed Kennell said: I have always found the Eaton 700 in the ***A tractors and the Eaton 1100 in the ***H tractors. Come on Ed, you know they wouldn't make it that logical. In the case of the 1985 314A it is a 700 but the 417A and 418A both came with the 1100 and the 516H had an Eaton 700. The only hard and fast rule with Wheel Horses is there are no hard and fast rules. 4 Share this post Link to post Share on other sites
953 nut 68,131 #5 Posted May 12 6 hours ago, BR2 said: New to the group and Wheel Horse mowers. Looking for some in put on drain plugs on hydro pump and transaxle.. would like to service them before run it to much. You have the Eaton 700 transaxle Do as @JoeM mentioned above to service your transaxle. 1 Share this post Link to post Share on other sites
JoeM 10,120 #6 Posted May 13 1 minute ago, 953 nut said: fast rules O'd Fast Eddie is pretty quick at selling from them there buckets! 1 3 Share this post Link to post Share on other sites
BR2 3 #7 Posted May 13 Thanks for the help glad I joined the group 1 Share this post Link to post Share on other sites
