My_horse 115 #1 Posted Monday at 03:06 PM Had the 314-8 out and put the mower on to mow the rough areas of the yard. Decided to change the trans oil while it’s good and warm. Probably better than 15 years since it was done last. This is what came out: shift boot is good, tractor is stored in a shed. Should I flush it with diesel or just refill with new oil? thanks 1 Share this post Link to post Share on other sites
ebinmaine 78,615 #2 Posted Monday at 03:15 PM 8 minutes ago, My_horse said: flush it with diesel 2 Share this post Link to post Share on other sites
Handy Don 16,462 #3 Posted Monday at 04:14 PM 1 hour ago, My_horse said: flush it with diesel And properly dispose of everything coming out of the transaxle! 2 1 Share this post Link to post Share on other sites
My_horse 115 #4 Posted Monday at 04:50 PM Just filled it with diesel and ran it around in all gears for 5 minutes. drained it out. going to let it sit for an hour with the front jacked up. Gotta see what I’ve got for oil. Should I fill with oil and be done with it, or run it a while, drain it and fill again? thanks again. 1 Share this post Link to post Share on other sites
ebinmaine 78,615 #5 Posted Monday at 04:54 PM You could go either way on that one. If it was me I probably would do another diesel flush. 3 Share this post Link to post Share on other sites
ri702bill 12,055 #6 Posted Monday at 06:31 PM I do not see the tractor raised so that the wheels can spin freely. Just dropping the fluid and refilling is inadequate to alleviate an issue with moisture in the Unidrive. That leaves too much comtaminated fluid clinging to the innards. A diesel flush is best - but - the Unidrive must be cycled thru all the gears - and hi & low ranges to get the sufficient "waterfall wash". Either by driving it or jacking it up in place. If you want to be amazed with the "waterfall" effect, pull the shifter out while doing the flush & look in.....The differential & gears spinning make for quite the splash. 1 1 Share this post Link to post Share on other sites
Handy Don 16,462 #7 Posted Monday at 06:37 PM 3 minutes ago, ri702bill said: ...The differential & gears spinning make for quite the splash. The pinions and other differential internals only get worked when the rear wheels turn at different speeds--do some circles on your “drive around”! 2 Share this post Link to post Share on other sites
ri702bill 12,055 #8 Posted Monday at 07:10 PM And DO look in the botton of the pan as you empty it for any "Gee, I don't think these should be here" bits - broken gear teeth, metal particles, or stray loose bearing needles.... Finding those is a game changer..... 3 Share this post Link to post Share on other sites
peter lena 9,868 #9 Posted Monday at 08:45 PM @My_horse regularly check my trans oils , always in an oil looking state , clean / clear , no issues , something i use for a trans flush is hi mileage , atf fluid , and put some miles on it , have a number of cul de sacs , housing areas near me , use every gear , hi / low range , also like climbing gear oil , read specs , grease the underside of shift boot ? so it easily slides over the irregularities on top of trans , like a tye wrap just above the shift boot on the metal stick . do a regular trans check after every usage , no surprises , drop mine , 3 / 4 years , think you left a lot of debris in the trans , crannies . also a great time to red aerosol grease every related linkage movement point , penetrating oil make the rust run out . pete 1 Share this post Link to post Share on other sites
My_horse 115 #10 Posted Monday at 09:03 PM The diesel rinse should have worked. Didn’t find any stray metal in the pan, so that’s good. I ran it around in all gears and did lots of turns. I’ll probably change it again before winter, just to be safe, and keep a better eye on the condition. Plus, change it on a more regular basis. Like maybe every 2 oil changes. filling the oil was sort of a pain. I put as much in as I could through the fill plug, until it started running out. Then put the rest in through the dipstick tube. That takes some time. 4 Share this post Link to post Share on other sites
ri702bill 12,055 #11 Posted Monday at 09:33 PM Depending on the model - I find it easier to remove the shifter & fill thru that hole. The 854 is a snap that way, the C81 is not... 5 1 Share this post Link to post Share on other sites
ebinmaine 78,615 #12 Posted Monday at 11:07 PM 1 hour ago, My_horse said: The diesel rinse should have worked. Didn’t find any stray metal in the pan, so that’s good. I ran it around in all gears and did lots of turns. I’ll probably change it again before winter, just to be safe, and keep a better eye on the condition. Plus, change it on a more regular basis. Like maybe every 2 oil changes. If you do that a couple times and notice that the fluid is staying clear, knock it back to every fourth or sixth. Gear oil in a Wheelhorse manual transmission lasts awhile but obviously contaminants like condensation aren't great. 1 hour ago, My_horse said: filling the oil was sort of a pain. I put as much in as I could through the fill plug, until it started running out. The side fill plug isn't actually the correct fill port for a 6 or 8 speed. That's a leftover from the original 60s casting. Capacity is 2 qts. Fill all from the top. 1 hour ago, My_horse said: Then put the rest in through the dipstick tube. That takes some time. You can make up a specific funnel for the application that has a long straw taped to the inside. This allows fluid in and air out simultaneously. 3 Share this post Link to post Share on other sites
sqrlgtr 2,798 #13 Posted Tuesday at 12:28 AM I always take one or both of the bolts out of top of transaxle to let it breath while filling um back up. Just make sure you don't let any trash fall in through the bolt holes especially on the hydro's 3 Share this post Link to post Share on other sites
Bill D 2,829 #14 Posted Tuesday at 01:46 AM 1 hour ago, sqrlgtr said: I always take one or both of the bolts out of top of transaxle to let it breath while filling um back up. Just make sure you don't let any trash fall in through the bolt holes especially on the hydro's On the hydros, just leave the filter loose until you've got at least 4 qts back in it. That lets the air out. Never had to do that on an 8 speed. Air can escape from around the shifter. 2 Share this post Link to post Share on other sites
ineedanother 2,262 #15 Posted Tuesday at 03:09 AM 6 hours ago, My_horse said: The diesel rinse should have worked. Didn’t find any stray metal in the pan, so that’s good. I ran it around in all gears and did lots of turns. I’ll probably change it again before winter, just to be safe, and keep a better eye on the condition. Plus, change it on a more regular basis. Like maybe every 2 oil changes. It depends on the lube you use and how hard you work it. Don't overthink it. Pull the dipstick when you do any service. You'll know when to change it. If in doubt, do it. 4 Share this post Link to post Share on other sites
peter lena 9,868 #16 Posted Tuesday at 12:29 PM @ineedanother have a regular shut down , schedule , engine oil / trans oil / check , verify statis , top off tank add 1 / 2 ounces of stabil fuel storage additive , general look over , things I regularly do are evolved over my 40 plus years of horse ownership , often refer to liking , repetitive problems ? often , literally showing you the way , make a change , you know what does not work . have zero , fuel hose related issues , years ago , cleaned out fuel tank , all new hoses , filter at tank and just before carb , sta bil storage treatment in all my fuels , carb bowls always clean / clear , that mind set on repetitive issues is home base for me , roller stool , sit and look / watch , how can I eliminate this ? pretty simple . the change literary hides in plane site . like a pto lever improvement , mule drive detailing , dare I say it ? frame length steel fuel line ? eliminate a lot of rubber hose , close to my end , pete 1 Share this post Link to post Share on other sites
John c 155 #17 Posted 8 hours ago I just had the same experience with this C101 I've got, shift boot all but gone, transaxle seal leaking, I did a diesel flush, then followed that with 2qts of cheap 10w30 I'll let that run in there for a few hours of actual use then drain/refill with 90wt 1 Share this post Link to post Share on other sites
