My_horse
Trans flush Y/N?
My_horse
Had the 314-8 out and put the mower on to mow the rough areas of the yard. Decided to change the trans oil while it’s good and warm. Probably better than 15 years since it was done last. This is what came out:
shift boot is good, tractor is stored in a shed. Should I flush it with diesel or just refill with new oil?
thanks
ebinmaine
:handgestures-thumbupright:
Handy Don
And properly dispose of everything coming out of the transaxle!
My_horse
Just filled it with diesel and ran it around in all gears for 5 minutes.
drained it out.
going to let it sit for an hour with the front jacked up. Gotta see what I’ve got for oil.
Should I fill with oil and be done with it, or run it a while, drain it and fill again?
thanks again.
ebinmaine
You could go either way on that one. If it was me I probably would do another diesel flush.
ri702bill
I do not see the tractor raised so that the wheels can spin freely.
Just dropping the fluid and refilling is inadequate to alleviate an issue with moisture in the Unidrive. That leaves too much comtaminated fluid clinging to the innards.  A diesel flush is best - but - the Unidrive must be cycled thru all the gears - and hi & low ranges to get the sufficient "waterfall wash". Either by driving it or jacking it up in place. If you want to be amazed with the "waterfall" effect, pull the shifter out while doing the flush & look in.....The differential & gears spinning make for quite the splash.
Handy Don
The pinions and other differential internals only get worked when the rear wheels turn at different speeds--do some circles on your “drive around”!  :rolleyes:
ri702bill
And DO look in the botton of the pan as you empty it for any "Gee, I don't think these should be here" bits - broken gear teeth, metal particles, or stray loose bearing needles...:o. Finding those is a game changer.....
peter lena
@My_horse  regularly check my trans oils ,  always in an  oil  looking state , clean / clear  , no issues ,  something  i use for a trans flush is hi mileage , atf fluid  , and put some miles on it  , have a number of cul de sacs  , housing  areas near me , use every gear , hi / low range , also like  climbing  gear oil , read specs , grease the underside of shift boot ?  so it easily slides over the irregularities  on top of trans , like a tye wrap  just above the shift boot  on the metal stick . do a regular trans check after every  usage , no surprises , drop  mine  , 3 / 4 years  , think you left a lot of debris in the trans , crannies . also a great time to  red aerosol  grease every related  linkage movement point , penetrating oil make the rust run out . pete
