sqrlgtr 2,770 #1 Posted 3 hours ago (edited) Wanting to add an electric fuel pump to my 520H and was hoping to get some ideas/suggestions/pics of mounting locations. I done a search on here, but a lot of the pics are gone and not much about mounting locations but more about wiring. Pics don't necessarily have to be 520's only. I have everything to add a rear lift to the 520 so under the seat/fender may be out (looks to be really tight) but I havent had a chance to check it out good yet. This is the pump I will be installing. Thanks for your attention to this matter!!! Edited 3 hours ago by sqrlgtr Share this post Link to post Share on other sites
Bill D 2,797 #2 Posted 2 hours ago (edited) I substituted the NLA Onan pump for this Kawasaki pump. Mounting bracket is from a Kawasaki. If you go the electric pump route, connect the positive wire to the positive terminal on the coil. If the safeties are activated the pump will shut down along with the engine. Edited 2 hours ago by Bill D 2 Share this post Link to post Share on other sites
Achto 31,697 #3 Posted 2 hours ago Jim has his mounted under the seat. @WHX?? you have any pics to share? Share this post Link to post Share on other sites
