squonk 48,119 #1 Posted May 10 Restoring a tractor? Painting an engine? Watch this video on why you need to have clean metal (no paint) for your grounds and how it effects engine cranking, 4 4 Share this post Link to post Share on other sites
ri702bill 13,055 #2 Posted May 10 The electric engine fan on our old 1989 Old Cutlass Ciera stopped working. It would always come on when the AC was switched on, but no more. Jump the connector & it works fine.... There was a long threaded stud on the lower front of the engine with about 4 stacked ground wires, a washer & nut. Ahha - it was a fuzzy white color, not shiny metal. disassembled the stack, cleaned both sides of all the lugs & mount, and reassembled. A good smear of dielectric grease over them, ploblem solved... Looks like it was a poor choice in the ground location, open to road splash. 3 Share this post Link to post Share on other sites
953 nut 69,296 #3 Posted May 10 (edited) Unfortunately many people do not understand that an electrical circuit needs a return path to work. Electrons can't just flow out (potential energy) and do work, they need to go through the device (light, motor, etc.) and back to the battery to do work. Edited May 10 by 953 nut 3 1 Share this post Link to post Share on other sites
oldlineman 1,809 #4 Posted May 10 That is the whole reason for Insulate and Isolate when we work safely on AC circuits. One of the first things we learned as apprentices. 1 Share this post Link to post Share on other sites
pfrederi 21,150 #5 Posted May 10 You can trust your mother not your ground.... 3 5 Share this post Link to post Share on other sites
WHX?? 58,119 #6 Posted May 10 2 hours ago, ri702bill said: it was a fuzzy white color I've got an a aluminum trailer and the lights always give problems. The lights are grounded to the frame with a self tapping screw and the dissimilar metals corrode the terminal rings. Would guess the same thing can happen on aluminum engine blocks. 5 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #7 Posted May 10 We had a K10 Chev Blazer come in with a noisy drivetrain. Every bearing in both front and rear axles, U-joints, differentials, transfer case and transmission had failed. Cause was a poor ground between the body and the battery. Current was flowing through the bearings to get to the engine which had a good ground. A very costly repair to a vehicle less than a year old. I should add that the cause was discovered before the damage was found. The technician had the radio on and when he removed one end of a drive shaft the radio quit. 1 1 2 Share this post Link to post Share on other sites
squonk 48,119 #8 Posted May 10 39 minutes ago, WHX?? said: I've got an a aluminum trailer and the lights always give problems. The lights are grounded to the frame with a self tapping screw and the dissimilar metals corrode the terminal rings. Would guess the same thing can happen on aluminum engine blocks. Had a real good one way back in 1980. Olds Omega with a manual trans. Under warranty came in with a broken clutch cable at the bellhousing. so I replaced it. Came back a month later with another broken cable. So I replaced it again. This time it looked like the cable was burnt. Turned out the negative cable at the bellhousing was loose 5 inches away from the cable. When starting an arc jumped between the cables and burned through the clutch cable. I have also seen choke and throttle cables glow on Wheel Horses! 5 Share this post Link to post Share on other sites
Ed Kennell 47,320 #9 Posted May 10 2 hours ago, WHX?? said: dissimilar metals corrode I had a new 1970 Jeep Wagoneer that would just shut down while cruising along along at 65. I found thet it would restart if I disconnected and reconnected a multi pin connector located on top of the radiator. after several shut downs, I cut out the connector and connected each wire. Several months later I got a recall from Jeep to get the connector replaced. Seems the male pins were brass and the female sockets were aluminum. 2 1 Share this post Link to post Share on other sites
Razorback 1,370 #10 Posted May 10 We have a 1981 Ford Bronco. I’m not sure how many model years are plagued by this, but I bet it’s several: the electric rear window is notorious for getting very slowwwwwwwwwwwwwww to go up and down, if at all. Happily, I fixed ours by cleaning up a ground point behind the rear left brake light housing. 2 Share this post Link to post Share on other sites
oldlineman 1,809 #11 Posted May 11 22 hours ago, WHX?? said: I've got an a aluminum trailer and the lights always give problems. The lights are grounded to the frame with a self tapping screw and the dissimilar metals corrode the terminal rings. Would guess the same thing can happen on aluminum engine blocks. Probably best fix for this problem is running a common ground from each load point back to the battery (power source). A little more work and cost but eliminates grounding problems. 2 Share this post Link to post Share on other sites
WHX?? 58,119 #12 Posted May 11 1 hour ago, oldlineman said: running a common ground from each load If I had to rewire the trailer that is exactly what I would do. 1 Share this post Link to post Share on other sites
953 nut 69,296 #13 Posted May 12 Case in point, we have a member I was working with on a mystery wiring problem, turned out to be dissimilar metals resulting in poor grounds. 1 Share this post Link to post Share on other sites
adsm08 5,146 #14 Posted May 12 On 5/10/2026 at 8:56 AM, WHX?? said: I've got an a aluminum trailer and the lights always give problems. The lights are grounded to the frame with a self tapping screw and the dissimilar metals corrode the terminal rings. Would guess the same thing can happen on aluminum engine blocks. Better to use a floating ground on aluminum. 2 Share this post Link to post Share on other sites
