ineedanother
Flywheel Puller
ineedanother
My apologies if this has been addressed before since I suspect it has, but I got exhausted before the search did :lol:
I need a good puller for this flywheel (k341). This one has likely never moved since installed but it's in pretty good condition. I could probably manage but wouldn't shy away from acquiring a good tool for this since I have a few others with similar needs. TIA.
wallfish
No puller required
Wedge the flywheel from the back against the plate but not super tight. I use 2 large screwdrivers spaced apart on each side. Loosen the nut so it's at the edge of the threads plus a tad tp protect the threads. Smack the nut with a brass hammer and viola. the flywheel is off.
A piece of hardwood and any old hammer will wok if you don't have a brass hammer.
I've yet to have a flywheel that didn't come off doing it this way
Edited by wallfish
  • Like 5
Handy Don
The blown Onan P220 that I parted had an awkward and stubborn flywheel. The service manual showed a simple puller with four screws through a plate and into threaded holes in the flywheel. Made it about 15 minutes. Snug then a bit more on the screws and a tap on the plate with a mallet and had the flywheel off in about 2 minutes.
And yes leaving the nut on the crankshaft is critical. Bust or chip a fin and you’re done and cursing a blue streak.
Edited by Handy Don
ineedanother
18 minutes ago, wallfish said:
No puller required
That's how I've done it in the past and trust it, but have always been concerned about damaging the bearing plate and I don't think this one has been off in 50 years.
ineedanother
Hard for me to believe, but I don't think this thing has ever had it's skirt lifted :lol:
wallfish
Don't pick the weak points of the plate to wedge it and it'll pop off without breaking the plate.
Doubtful most I've popped off were ever done before.
Did you actually try it yet? You can use wood wedges behind it but then you gotta smack that nut/crank end much harder to make up for the give of the wood. :twocents-02cents:
ineedanother
No, I haven't tried yet and don't doubt that I can get it off but just looking for best practice to avoid any adverse outcomes. I'm pretty confident I can wedge it off with pressure and impact.
wallfish
If that doesn't work then buy a puller but you'll probably still need to wack the bolt. Those holes in it are only 1/4-20 threads so use all 4 holes for a puller or something that can get under the edges of the flywheel.
ineedanother
Overanalyzed...:hide:
squonk
The proper type of puller is a harmonic balancer puller. Cheap enough and if you're cheaper you can rent them at some auto parts stores. Clean out the bolt holes with a tap first! :banana-wrench:
Acymner Harmonic Balancer Steering Wheel Puller Kit | 13PCS Flywheel Puller, Crankshaft Pulley Puller, Crankshaft Pulley R...
JoeM
that is what I use.
I pretty much quit beating on the shaft when I was taking the bearing plate out of an engine. The bearing was super tight on the shaft and snug as a bug in the plate. The only play was in the bearing.
For all it takes to use a puller I just don't like relying on that small amount of play.
Retired Wrencher
Lots of good info in this post! Nice job guys.
