horseman with no horse
onan oil filter cooling gasket
the rubber ring that goes around my p218 oil filter broke. i know that sucker is pretty essential to cooling. do you guys know where i could get one?
lynnmor
That gasket is now hard to find, Google Onan 122-0502 to search for one, you might get lucky.  The Case website mentioned above has a solution if you can't find the original.
JoeM
Just wondering if a piece of fuel line could be split and put around the opening?
  • Excellent 1
WHX??
Excellent idea Joe. There are many different sizes of automotive vacuum line tubing a guy could try.
sqrlgtr
Posted (edited)
I think anything that would direct the air toward #2 cylinder insted of letting it escape around the oil filter would work. I have tried running mine without for a minute or two just to see how much air you loose and it is indeed a lot!
Edited by sqrlgtr
Streetrodchev
When my filter air gasket broke, I used weather strip glue to put it back on, and then ordered a new one. It stayed in place until I changed oil the following time, at which time I put a new one on.
top_cat
Lost mine in the field a few weeks ago. Ordered one on EBay for $13.95. Found the original one few days ago. They are identical in fit and material. Hope this helps.
DLF
I have to have mine clamped between the front and side cover to keep it in place. The Onan moves a lot of air and will blow it out.
The part no. is 0122-0502.
