glenn27 71 #1 Posted May 4 Morning here-been a while for me to pot. looking for some info on a Kohler k301S engine, in a 1970 that has been sitting a while. Some parts off teh front of the engine in a box. I need the exact diagram of the governor arm/throttle control pieces as they go together=-I may be missing some pieces. Ben while since I worked on one of this model. Thanks for any info- glenn Share this post Link to post Share on other sites
ebinmaine 80,278 #2 Posted May 4 I made this a few years ago for a similar inquiry. Might help ya. Share this post Link to post Share on other sites
glenn27 71 #3 Posted May 4 Thank you-Sir, I need to know the order of those parts that actually hold that lever in the middle of the motor to the front of the motor I know there is a little spacer I have and two washer and an L bracket which is the stop-but that has to somehow pivot, I see. Share this post Link to post Share on other sites
ebinmaine 80,278 #4 Posted May 5 2 hours ago, glenn27 said: Thank you-Sir, I need to know the order of those parts that actually hold that lever in the middle of the motor to the front of the motor I know there is a little spacer I have and two washer and an L bracket which is the stop-but that has to somehow pivot, I see. Been awhile since I've had one apart but I believe that pivot you're looking for is a shoulder type spacer. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #5 Posted May 5 https://www.partstree.com/models/k301-47371-kohler-k-series-engine-made-for-wheel-horse-12hp-9kw/remote-throttle-24-10-10-tp-2097-32/ Share this post Link to post Share on other sites
