Wheelhorse3128 7 #1 Posted 6 hours ago Planning on making a blade but first need brakets and I would like to know if anyone could give me some dimensions Share this post Link to post Share on other sites
Ed Kennell 45,848 #2 Posted 5 hours ago 52 minutes ago, Wheelhorse3128 said: dimensions Are we talking. all of the below? axle bracket plow frame blade angle sector angle lever 2 Share this post Link to post Share on other sites
953 nut 65,486 #3 Posted 5 hours ago (edited) 1 hour ago, Wheelhorse3128 said: but first need brakets and I would like to know if anyone could give me some dimensions The rear axle bracket is built of a pair of angle iron pieces with a 3/4" round top slot cut in the bottom as pictured below. They do not need to be welded to the cross bar but will need the two bolts each and the heavy bracket for the other side of your axle. The arm that swings under the snow plow's 3/4" rear cross bar is pictured. I have no dimensions to give you but the frame of the snow plow will go between the angle irons. For a 312-8 you would want the angle iron pieces mounted with the ears outward rather than inward, this is the only good picture I have and it is for the older short frame tractors. Edited 5 hours ago by 953 nut Share this post Link to post Share on other sites
Ed Kennell 45,848 #4 Posted 4 hours ago Here is a picture of the axle bracket on my 312H. Use the axle size as a reference. 1 Share this post Link to post Share on other sites
Wheelhorse3128 7 #6 Posted 2 hours ago Also dose anyone have drawings or dimensions of the snow plough frame without the blade on? Share this post Link to post Share on other sites
DLF 28 #7 Posted 1 hour ago (edited) Can't give exact width detention as mine not factory. If you are using a angle like Ed's it looks to be a 2"x 4" angle. Lee1977 Edited 1 hour ago by DLF Share this post Link to post Share on other sites
Handy Don 16,344 #8 Posted 1 hour ago 1 hour ago, Wheelhorse3128 said: Also dose anyone have drawings or dimensions of the snow plough frame without the blade on? I’d suggest you post a sketch (or pictures) of the items you’re interested in marked up with the dimensions you need. The front blade frames varied over the several tractor models (short-, “medium-”, and long-frame) so it matters what model of tractor you have. Share this post Link to post Share on other sites
Ed Kennell 45,848 #9 Posted 1 hour ago Wish you were closer. I have complete plows for $100. Share this post Link to post Share on other sites
