Pullstart 70,035 #51 Posted 18 hours ago On 5/7/2026 at 7:58 PM, ineedanother said: I've had issues in the past with the #3 phillips for the screen on the flywheel. I've soaked these for a few days and hit them with the manual impact. Four for 4 On 5/7/2026 at 8:10 PM, ebinmaine said: Niiiiice. That manual impact driver was a recommended purchase by the folks here on Redsquare several years ago when we restored my 1974 C160-8 Cinnamon Horse. EXCELLENT purchase. Whack! To tighten. Then loosen. Repeat. Remove. On 5/7/2026 at 10:24 PM, Handy Don said: Sadly, mine was a hand-me-down from the late 40s and doesn’t support sockets. But it DID come with a fat blade for slotted screws which has been terrific on a lot of old furniture work. You have a lot more control than with a powered impact driver. Lots of good info in these posts! Tightening to loosen. That’s huge! Shock the threads, but don’t gall them. It was a trick an engineer who came from lab work taught me a long time ago. It works great with pipe threads especially. Impact drivers. They are cheap and I use mine often. Sometimes however, I’ll hang a large box end wrench on my closest screw driver handle and give it some taps with a small hammer or dead blow. It typically does the trick and costs no money if the tools are available. I’ve never broken a screwdriver handle using it as an impact, but I have broken plenty using them as chisels. 3 Share this post Link to post Share on other sites
adsm08 4,518 #52 Posted 14 hours ago 3 hours ago, Pullstart said: Tightening to loosen 110%. I just did this with the remainder of a broken cab bolt. 1 Share this post Link to post Share on other sites
ebinmaine 79,053 #53 Posted 13 hours ago 41 minutes ago, adsm08 said: 110%. I just did this with the remainder of a broken cab bolt. One of the techs at the GM garage I worked at 25 + years ago used to tell us.. You can almost never loosen it, but you can almost always tighten it. Then loosen. Then tighten. Repeat. Repeat. Repeat. Repeat. What a cool trick. I've even seen a guy use that on the plastic fasteners for a plastic grille. 2 Share this post Link to post Share on other sites
adsm08 4,518 #54 Posted 6 hours ago 7 hours ago, ebinmaine said: One of the techs at the GM garage I worked at 25 + years ago used to tell us.. You can almost never loosen it, but you can almost always tighten it. Then loosen. Then tighten. Repeat. Repeat. Repeat. Repeat. What a cool trick. I've even seen a guy use that on the plastic fasteners for a plastic grille. In my situation my cab bolts are essentially double nutted. There is a washer under the floor with a hex on it, and threads inside. Then there is another washer with a nut welded to it facing the ground at the bottom. My bolt broke off in the cab leaving both sets of threads tight and no way to grab it. I couldn't get a weld to take either, but I did melt the threads enough I could push it in with another nut. Share this post Link to post Share on other sites
