ebinmaine
6 hours ago, ineedanother said:
One thing I didn't care for was driving the pins back in. I used some 320 grit and assembly grease and still peened them a bit. Hit them with grinder and they're good to go, plenty of clearance for the pulley and not going anywhere!
2 hours ago, kpinnc said:
Had that trouble before myself. On the last one I did, I also just drove to top pin until the hole was plugged and ground the excess off flush as you did.
Same.
ineedanother
Things add up quickly :( No oil pan gaskets on the shelf so I ordered two, I need solid mounts for the recently acquired c-161 and that isn't even in the shop yet, it needs wheel studs so ordered them from M-C and forgot to order head bolts for the 16 Auto so I'll pay shipping twice for that lack of paying attention. I was going to order a soft start for the electric clutch but I better slow my roll before the Colonel looks at the checking account :lol:
One potential positive is that the valve lash was out enough to maybe account for some of the rough running. Intake .011 and exhaust .014. They look good and nothing else is concerning so I'll just lap and adjust them until there's a need to go further.
  • Like 5
ebinmaine
What's the spec?
Around  .008 & .018. ?
ineedanother
3 hours ago, ebinmaine said:
What's the spec?
Yeah, I think between that and timing being off a little can take away from performance. I might be overthinking it a bit but we'll see.
ineedanother
Waiting on an oil pan gasket to start much reassembly but the head bolts came today so I thought I would go ahead and start on some of that. Blocked the head on granite with some 320 grit. Nice and flat :thumbs:. Chased the threads in the block, adjusted the valves and reassembled the breather. I'll wait to torque the head until it's back on the frame. It's just easier when it's not sliding around on the bench.
  • Excellent 4
ineedanother
6-8 days delivery for the oil pan gasket so I've caught up on some chores around the house and painted the front wheel weights...but this is a good time (pun) to set the timing...I'll attach the ground wire with a new grommet and dialectric grease when it's ready to brrrrrrr.
ineedanother
Forgot the pics :lol: I swear...I haven't weighed them but they're heavy.
  • Excellent 2
ineedanother
The oil pan gasket finally shipped this morning but...USPS :crying-yellow:I suspect it will be creased right between the "O" and "T" in "DO NOT BEND" but we'll see. Installed in-line fuses for the clutch and ammeter. Not much else to do until I get the block bolted down.
  • Like 4
  • Haha 1
  • Sad 1
ineedanother
And...the oil pan gasket made it safely and fit in the mail box without getting bent  :thumbs:. Got the pan on so things should move along now. I tidied up some wiring on the brake switch and verified its operation. Drained the lift cylinder since I'm changing from ATF and got it back in place. If the weather allows I'll get the welder out to do some repairs on the battery box and belt guard. Things should move along quickly if that happens. Hopefully the weather will cooperate.
ineedanother
This might look like a bit of a mess but hopefully that's because my shop is so small. Some progress...engine back together and bolted down. All wiring tidied up and ready to finish. Throttle and choke cables robbed from donors. Battery box and belt guard repaired but I won't brag about my welding :lol: Most of the long block components are back in place. Shout out to my wife for appreciating how enjoyable this is for me to get in the shop and work :) We did manage to get steaks on the grill and share a bottle of wine in spite of the weather :thumbs:.
  • Excellent 3
ineedanother
Quite a bit of progress today but it's raining like you know what so everything got pushed back into my small shop. I made myself be patient with the wiring, throttle and choke cables, and getting the sheet metal back in place. I have to find a solution for the exhaust but she burns fuel again and I got the head torqued down x3 and one test drive until the skies opened up again. Getting close...
  • Excellent 4
ineedanother
Not much time on a work day but trimmed the left foot rest to clear the front hydro lift hose. I had to do that on another and really don't see a good way around it.
Salvaged an exhaust elbow from an M10 I had in the garage. Still looking at exhaust solutions and this gives me another. I've actually been spraying that for 6 months or so and an old 1 1/8" axle fit perfectly in the outlet so a little persuasion broke it loose :thumbs:
Bar Nuthin
Posted (edited)
I just put new front hoses on my 16. I have the front hose in front of the rear hose
IMG_5187.jpg.6ba9609ddb3287125ab5369b5783c099.jpg  IMG_2653.jpg.9d50f5eb03d411ca07a0786933338559.jpg
Edited by Bar Nuthin
ineedanother
Interesting, maybe. It looks like the bore for the fitting on your cylinder is more lateral than mine.
  • Confused 1
Bar Nuthin
Seems unlikely - :dunno:
ineedanother
Anyone who's ever replaced the pesky brake pedal return spring on a sundstrand hydro unit knows that it's in the hood stand and can be an exercise in patience. I've seen some workarounds so that's what I chose to do this morning. I'll swap the angle bracket out for something more appropriate but this was effective for testing purposes. I can't recall what these springs are for but I have a few in the shop so they're likely a common :wh: part.
  • Like 5
ineedanother
Well, it's been almost a month and it's back together. I wouldn't call it a restoration but I got the hydro/uni-drive replaced and the balance gears removed which were the primary objectives. I got seat springs and an old Nelson on it this afternoon and will do a few more things as I get time, but for now I'll call it good and move on to another project that's been waiting...
  • Excellent 5
adsm08
Looks a lot like the PTO tension spring on my two units.
ineedanother
I think it's bigger than that but it could be. It might be a brake spring from an 8-speed.
peter lena
@ineedanother  done a lot of this , makes for a perfect era patina , there is no dust or dirt on my paint , just solid clean , now retained , only thing i  use on it is s light penetrant , mineral oil clean cloth , that 6" electric palm buffer  , cleaner wax , makes it easy , pete
adsm08
Maybe. I don't have any 8 speeds, but those two springs on my tractors are similar in size.
I think they are also the same dimensions as the springs on our trampoline.
kpinnc
Looks fantastic from here! Very nice job! :thumbs:
ineedanother
I'm giving Penetrol a try on this and I'm okay with it so far. I'll let you know what the verdict is after a few treatments :thumbs:
ebinmaine
:text-yeahthat:
Please keep us posted!
ineedanother
Impressed with the Penetrol (Flood). Two applications. Not much sun here but it's completely dry after two days. Not tacky or oily. I like it. :thumbs:
  • Excellent 3
