ineedanother 2,165 #1 Posted Sunday at 02:33 AM Not sure what the end game is for this but it's too good to let go. It's got some issues but is largely original. I'm going to start with a gearbox for axle issues and penetrol treatment to preserve the patina... 8 3 1 Share this post Link to post Share on other sites
ebinmaine 78,484 #2 Posted Sunday at 12:04 PM Good looking original there. Definitely worth the effort of saving. Some touch ups here & there and you'd have a great rig. 2 Share this post Link to post Share on other sites
kpinnc 18,047 #3 Posted Sunday at 06:21 PM 15 hours ago, ineedanother said: too good to let go Agreed 100% 2 Share this post Link to post Share on other sites
ineedanother 2,165 #4 Posted Sunday at 06:58 PM Lots going on today other than tractors but I'll get some of it done... 1 Share this post Link to post Share on other sites
ineedanother 2,165 #5 Posted Sunday at 07:56 PM The drain plug is stripped so no draining the ATF but I did manage to get the good hub off and that axle looks fine. 1 Share this post Link to post Share on other sites
ineedanother 2,165 #6 Posted Sunday at 09:23 PM I forgot I could drain the case from the bottom of the motor, 3 quarts of clean ATF. Pulled the pump and motor to make it more manageable from a weight perspective. Found a nice comfy nest of insulation and nuts in with the controls. Got the gear box off and will get the frame cleaned up but everything looks good and solid. I would really like to have a roller again today but my old self is close to done getting up and down off this floor. 2 2 Share this post Link to post Share on other sites
ineedanother 2,165 #7 Posted Sunday at 11:17 PM Well, it's a roller. I really could have had it all back together today but too many other distractions and no ATF on the shelf either. Tomorrow's another day... 3 Share this post Link to post Share on other sites
ineedanother 2,165 #8 Posted Monday at 11:51 PM I have power. Converting over to 10-30 so need to drain the lift cylinder and have a list of other things to address but this was a big line item 2 Share this post Link to post Share on other sites
ineedanother 2,165 #9 Posted 12 hours ago Needs a good bit of attention elsewhere, to be expected being a '73 with no records and not much known about its history. Someone has been pumping grease into it but the fuel pump leaks, most of the wiring is original, I can't tell yet if the head has ever been pulled and doubt that the valves are in adjustment by the way it runs...stuff to do I'd like to pull the balance gears but I've got other priorities and no tasks in mind for this one. We'll see how things shake out, it might be worth a couple hours to go ahead and do that while I'm this far in. 3 Share this post Link to post Share on other sites
ebinmaine 78,484 #10 Posted 4 hours ago 7 hours ago, ineedanother said: pull the balance gears , it WOULD ABSOLUTELY be worth a couple hours to go ahead and do that while I'm this far in. Eliminating or replacing the grenade gears will be a mandatory maintenance procedure here from now on. Period. Share this post Link to post Share on other sites
kpinnc 18,047 #11 Posted 9 minutes ago 3 hours ago, ebinmaine said: Eliminating or replacing the grenade gears will be a mandatory maintenance procedure here from now on. Period. I don't have a K341 to comment on, but on my Bronco's K321 (same crank), the increase in vibration was not nearly as bad as I feared it would be. It's definitely there, but knowing my engine is now safe from window making is easily worth it. I won't install another Kohler with the balance gears still in there. I like these old engines too much to take the chance. Share this post Link to post Share on other sites
