ri702bill
While it's off, maybe time to slosh some RedKote or similar tank sealer on the inside....
  • Excellent 2
Achto
Gonna run it the way it is now. This tractor is far from original, it's our 2 seater butt buggy at shows. The tank is all beat to heck. If it leaks again it will be replaced with an 8x18 spun aluminum tank.
8ntruck
What tools and supplies did you use for silver soldering?  I tried doing that on a model boat boiler.  Couldn't get the solder to stick.  I cleaned everything up and went to Stay Brite solder.  That is more of a lead/tin alloy with a low percentage of silver added - lower melting temperature.
Achto
After using a wire brush on a drill to get the metal super clean. I warmed the tank up & gave it a good coat of paste flux. Used a mini torch to heat the metal and used a silver bearing solder for metal work.
https://www.lowes.com/pd/Harris-Products-Group-3-oz-Lead-Free-General-Metal-Solder/1000858196
ri702bill
Oh joy! Working with lead free solder is a whole new animal...... much safer, but requires getting used to. Lead free does not go from shiny when wet to dull when solidified - it stays dull throughout the entide process. Tougher to gauge just what stage it is...
Edited by ri702bill
WHX??
I got a old pony keg if it needs a new tank... :lol:
Achto
Would be perfect !!!!
